1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: related to coding
To: priya tiwari <[email protected]>
Date: Sun, 1 Feb 2015 23:17:00 -0600
Note: these are NOT run time errors, your code doesn't even compile.
Sent from my iPad 4
On Feb 1, 2015, at 23:05, priya tiwari <[email protected]> wrote:
Thanks Sir,
I changed in a code but still i got the errors at run time.please provide me solution.
On Mon, Feb 2, 2015 at 9:50 AM, Mooney, Tim M. <[email protected]> wrote:
Hi Priya,
Return 2, instead of 0, from read_ai.  That tells the record that you put the value in VAL.  If you return 0, you are telling the record you put the value in RVAL, and that the record should convert RVAL to get VAL.
See "Device Support Routines" in
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of priya tiwari [[email protected]]
Sent: Sunday, February 01, 2015 9:54 PM
To: [email protected]
Subject: related to coding
Hello,
I am trying to write the value into val field of ai record from device support.I am beginner in EPICS so I have no idea about this. But i have tried then i got the errors at run time please help me.I am attaching code file.
Thanks in advance...
<Screenshot from 2015-02-02 10:30:06.png>
<dbtest.c>
Re: related to coding priya tiwari
RE: related to coding Mooney, Tim M.
Prev: Re: related to coding priya tiwari
Next: Re: related to coding priya tiwari
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
