On 1/28/15 10:22 PM, Rahul Jain wrote:
> Hello,
> When I just run 'make' without the 'sudo', I get following error
> message:-
> make -C ./configure install
> make[1]: Entering directory `/opt/epics/base-3-14-11/configure'
> perl ../src/tools/makeMakefile.pl O.linux-x86 ../..
> Cannot create O.linux-x86/Makefile at ../src/tools/makeMakefile.pl line 41.
> make[1]: *** [O.linux-x86] Error 2
> make[1]: Leaving directory `/opt/epics/base-3-14-11/configure'
> make: *** [configure.install] Error 2
> As you suggested, I tried to build the latest version 3.14.12.4
> by using 'make' without the 'sudo' and it also gave the same
> above mentioned error message, but when I used 'sudo make' it was
> successfully built and installed.
Hello, Rahul.
How did you extract the EPICS Base source to /opt/epics/base-3-14-11?
If you extracted it as root or with sudo, then the ownership and
permissions might be such that you could get this kind of error when
running "make" from your regular account.
One way to fix this would be the following, assuming your regular
account user is "rahuljain" and your group is "users":
$ sudo chown -R rahuljain:users /opt/epics/base-3-14-11
Now, as your regular user ("rahuljain") do the following:
$ cd /opt/epics/base-3-14-11
$ make clean uninstall
$ make
Lewis
- Re: Problem in building EPICS Johnson, Andrew N.
- Re: Problem in building EPICS Rahul Jain
Re: trouble building asyn driver on FreeBSD Andrew Johnson
Re: trouble building asyn driver on FreeBSD J. Lewis Muir
<2015>
Issues with installing the adPython plugin for areaDetector David Michel
<2015>
