Hi Franklin,
On 01/28/2015 09:02 PM, Franklin Fuller wrote:
> EPICS expects gcc, while FreeBSD ships with clang. I installed gcc/g++
> 4.8 into /usr/local/bin and then soft-linked them to /usr/bin. This
> allowed me to build base without any errors, but then I ran into these
> troubles with asyn.
EPICS can be built with clang (I have tested that on both Mac and
Linux), you just have to configure it properly. If new versions of
FreeBSD now use clang by default then we should change the freebsd files
in configure/os to assume that; you may be our only FreeBSD user at the
moment though, so you're going to have to help me with the changes that
are needed.
- Andrew
Doctorow's Law: Anytime someone puts a lock on something you own,
against your wishes, and doesn't give you the key, they're
not doing it for your benefit.
- Re: trouble building asyn driver on FreeBSD J. Lewis Muir
- trouble building asyn driver on FreeBSD Franklin Fuller
Re: struck sis3316 digitizer ADC data transfer with RTEMS Michael Davidsaver
Re: Problem in building EPICS J. Lewis Muir
<2015>
RE: trouble building asyn driver on FreeBSD Mark Rivers
<2015>
