Well the module is now built and usable, it’s just the example IOC that is failing. In the iocs/example/exampleApp/Db/Makefile there is a PATH:= directive,
you could try adding the path to msi in here and see if it helps...
Tom Cobb
Sent: 28 January 2015 10:16
To: Cobb, Tom (DLSLtd,RAL,TEC)
Cc: EPICS mailing list
Subject: Re: Issues with installing the adPython plugin for areaDetector
Thanks Tom,
I just deleted the protocol directory... it gets further but now fails at it cannot find msi although it is installed on the PATH...
make[3]: Entering directory `/usr/local/epics/support/adPython/adPython-0-2/iocs/example/exampleApp/Db'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[4]: Entering directory `/usr/local/epics/support/adPython/adPython-0-2/iocs/example/exampleApp/Db/O.linux-x86_64'
echo "../O.Common/example_expanded.db : " >> example_expanded.db.d
echo "example_expanded.db.d: " >> example_expanded.db.d
Inflating database from ../example_expanded.substitutions
msi -I. -I.. -I../O.Common -I../../../db -I/usr/local/epics/support/areaDetector/current/db -I/usr/local/epics/support/asyn/current/db -I/usr/local/epics/base/db -S../example_expanded.substitutions > example_expanded.tmp
/bin/sh: 1: msi: not found
On 28 January 2015 at 09:58, <[email protected]> wrote:
I’m a bit confused by the error, but the directory is not required for the build, so you can either
delete the adPythonApp/protocol directory, or comment out the line with $(wildcard protocol) in it in adPythonApp/Makefile.
Tom Cobb
[email protected] [mailto:[email protected]]
On Behalf Of David Michel
Sent: 28 January 2015 09:52
To: EPICS mailing list
Subject: Issues with installing the adPython plugin for areaDetector
I'm currently having issues with installing adPython 0.2 for AreaDetector (R1.9) on Ubuntu (12.04). All I did was 1) download the plugin 2) edit the RELEASE to the relevant path
of my system 3), type make at the top level.... but the build just stop when entering the adPythonApp/protocol giving me the error "No rule to make target 'install'"
It's probably something silly, but I cannot find what's wrong.... anyone seen this error before or has experience with installing this plugin?
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee
please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message. Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
