I have some motors using URIP = 1 that, after IOC boot and caput on
STUP = 1, get the correct value in RBV field, according to the PV
configured in RDBL and RRES resolution. But I suppose that VAL field
took a value based on motor driver counter and MRES. I tried to do
caput on SYNC field to get RBV value to VAL but it happened to work at
the opposite way - VAL value went to RBV.
I checked the motorRecord.cc file and I think the URIP = 1 case was
not defined there. If I'm using it in the wrong way, please point me
what is it. Otherwise I'd like to propose a modification in function
syncTargetPosition(motorRecord *pmr) of motorRecord.cc file. See it
below, please:
*** motorApp/MotorSrc/motorRecord.cc 2015-01-21 16:55:51.000000000 -0200
--- motorApp/MotorSrc/motorRecord.last.cc 2015-01-21
17:07:54.000000000 -0200
*************** static void syncTargetPosition(motorReco
*** 4035,4041 ****
pmr->rrbv = pmr->rep;
pmr->drbv = pmr->rrbv * pmr->eres;
! else if (!pmr->urip)
pmr->rrbv = pmr->rmp;
pmr->drbv = pmr->rrbv * pmr->mres;
--- 4035,4041 ----
! else if
I added "if (!pmr->urip)" on the else case.
I tested it and SYNC worked pretty fine in my case. I'm using motor
record 6-8 but I saw that 6-9 has the same code for the sync function.
Thank you for your attention,
Márcio Paduan Donadio
Computer Engineer - LNLS
RE: related to driver Mark Rivers
EPICS driver for CAENels HV-Adaptos? nicoletta.de-maio
<2015>
<2015>
