I'm trying to make an IOC for a digitizer, the redpitaya. I've assigned it a static IP address and can successfully ssh to it, doing However, there doesn't seem to be a specific port I should use in connecting to it - as least I see no mention of it in the documentation. I've tried using the "default" port numbers 5064,5065 in my st.cmd file, but both options give the Can't connect to 10.95.101.75:5064: No route to host L0 -1 autoConnect could not connect error message. I also get this warning cas warning: Configured TCP port was unavailable. cas warning: Using dynamically assigned TCP port 33122, cas warning: but now two or more servers share the same UDP port. cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST) but I've seen this with other IOCs for other devices, and those IOCs still work, so I'm assuming these warnings are not the fundamental issue. Does anyone know what other ports I should try or should I instead try to reconfigure the redpitaya and assign it a port as well? Thanks, Ana Malagon
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
