1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: calling the output of one record into another record
Cc: Eric Norum <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 15 Jan 2015 13:10:58 -0800
Hi Mark, Eric,
Thanks! That fixed it - and yep, the example I followed was from the HowToDoSerial_StreamDevice.html file.
Thanks!
Ana
On Thu, Jan 15, 2015 at 1:00 PM, Mark Rivers <[email protected]> wrote:
> Was there an example that you followed that had this error?  If so please let me know and I will fix it.
I found the answer to my own question.  HowToDoSerial_StreamDevice.html has this error, it does not show that you need to include “asyn.dbd”.  I will fix it now.
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: Thursday, January 15, 2015 2:58 PM
To: 'Eric Norum'; Ana Malagon
Cc: [email protected]
Subject: RE: calling the output of one record into another record
Hi Ana,
You got the following:
> drvAsynIPPortConfigure("L0", "10.95.101.76:5025", 0, 0, 0)
> asynOctetSetInputEos("L0", 0, "\n")
> st.cmd line 18: Command asynOctetSetInputEos not found.
The fact that the drvAsynIPPortConfigure command is defined but the asynOctetSetInputEos command is not suggests that Eric is correct.  I bet your application dbd file is including “drvAsynIPPort.dbd” but not “asyn.dbd”.
In asyn versions before R4-22 this was OK, because drvAsynIPPort.dbd itself included asyn.dbd.  But this is not allowed in EPICS 3.15, so you now must explicitly include “asyn.dbd”.
Sent: Thursday, January 15, 2015 2:17 PM
To: Ana Malagon
Cc: Mark Rivers; [email protected]
Have you added asyn.dbd  to your application?  The listing below shows a bunch of missing commands.
On Jan 15, 2015, at 11:50 AM, Ana Malagon <[email protected]> wrote:
Hi Mark,
Thanks -  I've moved over to StreamDevice and now have a very simpleminded question. I've created a test application following the instructions here; make runs successfully in my top directory. When I run st.cmd, however, I get a 'no reply from device with 1000 ms'. I believe I'm using up to date versions of asyn (4.22), stream (2.6), and base (3.14). I'm sure I'm missing something obvious - is there some other setup step that I should have done? Below is the output from st.cmd -
Ana
admx@admxcontrol:~/admxepics/devices/fieldfoxstream/iocBoot/iocFIELDFOXSTREAMtest$ ./st.cmd
#!../../bin/linux-x86_64/FIELDFOXSTREAMtest
## You may have to change FIELDFOXSTREAMtest to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocFIELDFOXSTREAMtest")
epicsEnvSet("TOP","/home/admx/admxepics/devices/fieldfoxstream")
epicsEnvSet("ASYN","/home/admx/epics/asyn4-22")
epicsEnvSet("STREAM","/home/admx/epics/StreamDevice-2-6")
epicsEnvSet("EPICS_BASE","/home/admx/epics/base-3.14.12.4")
epicsEnvSet "STREAM_PROTOCOL_PATH" "/home/admx/admxepics/devices/fieldfoxstream/db"
epicsEnvSet "P" "fieldfoxstream"
epicsEnvSet "R" "Test"
cd /home/admx/admxepics/devices/fieldfoxstream
dbLoadDatabase "dbd/FIELDFOXSTREAMtest.dbd"
FIELDFOXSTREAMtest_registerRecordDeviceDriver pdbbase
st.cmd line 18: Command asynOctetSetInputEos not found. <<<<<<<<<<<<<<<<!!!!!!!!!!!
asynOctetSetOutputEos("L0", 0, "\n")
st.cmd line 19: Command asynOctetSetOutputEos not found. <<<<<<<<<<<<<<<<!!!!!!!!!!!
asynSetTraceIOMask("L0", -1, 0x2)
st.cmd line 20: Command asynSetTraceIOMask not found. <<<<<<<<<<<<<<<<!!!!!!!!!!!
asynSetTraceMask("L0", -1, 0x9)
st.cmd line 21: Command asynSetTraceMask not found. <<<<<<<<<<<<<<<<!!!!!!!!!!!
## Load record instances
dbLoadRecords("db/devFIELDFOXSTREAM.db","P=fieldfoxstream, R=Test, PORT=L0, A=0")
cd /home/admx/admxepics/devices/fieldfoxstream/iocBoot/iocFIELDFOXSTREAMtest
iocInit
Starting iocInit
## EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$
## EPICS Base built May 20 2014
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 43138,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
## Start any sequence programs
#seq sncxxx,"user=admxHost"
epics> 2015/01/15 11:20:44.557860 L0 fieldfoxstreamTestIDN: No reply from device within 1000 ms
2015/01/15 11:20:45.559805 L0 fieldfoxstreamTestIDNwf: No reply from device within 1000 ms
Eric Norum
[email protected]
calling the output of one record into another record Ana Malagon
RE: calling the output of one record into another record Mark Rivers
Re: calling the output of one record into another record Ana Malagon
Re: calling the output of one record into another record Eric Norum
Prev: RE: calling the output of one record into another record Mark Rivers
Next: Support for Mercury iTC Emma Shepherd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Alarm annunciation with ALH and other PC based systems Rod Nussbaumer
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
