Subject: |
Re: How to access bigstring using channel access |
Ralph Lange <[email protected]> |
To: |
EPICS Tech-Talk <[email protected]> |
Date: |
Thu, 15 Jan 2015 08:33:35 -0500 |
Hi Deeptarka,
Try appending a dollar sign to the PV name when connecting through
Channel Access. The IOC takes that as a hint to represent a string
field as an array of char, so that CA can transfer more chars than
the fixed-size string would allow.
caget mybigstring.VAL --> string (fix 39
chars)
caget mybigstring.VAL$ --> array of char
(max EPICS_CA_MAX_ARRAY_BYTES - 1)
HTH,
~Ralph
On 15/01/2015 07:56, Deeptarka
Das/TVM/TCS wrote:
Hi all,
I would like to know if there is some way by which
channel access can be used to put and get strings of size
larger than 40. I do not wish to use waveform record nor do
i wish to use pvaSrv to access PVs using pvAccess. Rather I
would like to use the bigstring recordtype of EPICS V4 with
channel access. Is there any way it is possible by maybe
changing something in epics base?
Thanks and Regards,
Deeptarka Das
Mailto: [email protected]
- Re: How to access bigstring using channel access Deeptarka Das/TVM/TCS
- How to access bigstring using channel access Deeptarka Das/TVM/TCS
RE: industrial barcode reader Russ Berg
<2015>
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
