Hi Tim,
Can you try running a bazaar checkout of EPICS base today, and also using the git master branch of ADCore?
I just updated busy, calc, asyn, sscan, and autosave to the latest SVN versions, and it still fails for me.
Could it be a difference in the perl version? This is mine:
corvette:~/devel-3.15/areaDetector/ADCore>perl --version
This is perl 5, version 12, subversion 4 (v5.12.4) built for x86_64-linux-thread-multi
Copyright 1987-2010, Larry Wall
-----Original Message-----
Sent: Friday, January 09, 2015 1:49 PM
To: Johnson, Andrew N.; Mark Rivers; 'Heinz P. Junkes'; [email protected] ([email protected])
Subject: RE: areadetector dbExpand.pl error: Braces must be closed in the same file they open in.
I'm doing what I think is effectively the same build, but I don't see that error:
perl -CSD /home/oxygen/MOONEY/epics/base-3.15.1/bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../dbd -I/home/oxygen/MOONEY/epics/base-3.15.1/dbd -I/home/oxygen/MOONEY/epics/synApps_3.15/support/areaDetector-2-0/ADCore/dbd -I/home/oxygen/MOONEY/epics/synApps_3.15/support/asyn-4-25/dbd -I/home/oxygen/MOONEY/epics/synApps_3.15/support/calc-3-4-2/dbd -I/home/oxygen/MOONEY/epics/synApps_3.15/support/sscan-2-10/dbd -I/home/oxygen/MOONEY/epics/synApps_3.15/support/busy-1-6-1/dbd -I/home/oxygen/MOONEY/epics/synApps_3.15/support/autosave-5-5/dbd -o simDetectorApp.dbd simDetectorSupport.dbd commonDriverSupport.dbd
version differences:
your build my build
areaDetector-2-1 areadetector-2-0 (but I do have ADCore-2-1, which I think is the relevant version number)
calc-3-4-1 calc-3-4-2
busy-1-6 busy-1-6-1
autosave-5-4-2 autosave-5-5
The .dbd files are the same in these versions of calc, busy, and autosave
I'm also working against a bazaar checkout, last updated Dec 1, 2014, but I think it's 3.15.1
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Andrew Johnson [[email protected]]
Sent: Friday, January 09, 2015 11:43 AM
To: Rivers, Mark L.; 'Heinz P. Junkes'; [email protected] ([email protected])
Subject: Re: areadetector dbExpand.pl error: Braces must be closed in the same file they open in.
Hi Mark,
On 01/09/2015 10:16 AM, Mark Rivers wrote:
> Creating dbd file simDetectorApp.dbd
> perl -CSD /corvette/usr/local/epics/base-3.15.0/bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../dbd -I/corvette/usr/local/epics/base-3.15.0/dbd -I/corvette/home/epics/devel-3.15/asyn-4-25/dbd -I/corvette/home/epics/devel-3.15/areaDetector-2-1/ADCore/dbd -I/corvette/home/epics/devel-3.15/calc-3-4-1/dbd -I/corvette/home/epics/devel-3.15/busy-1-6/dbd -I/corvette/home/epics/devel-3.15/sscan-2-10/dbd -I/corvette/home/epics/devel-3.15/autosave-5-4-2/dbd -o simDetectorApp.dbd simDetectorSupport.dbd commonDriverSupport.dbd
> dbdExpand.pl: Leaving context "file '/corvette/home/epics/devel-3.15/areaDetector-2-1/ADCore/dbd/commonDriverSupport.dbd'", found "file '/corvette/home/epics/devel-3.15/areaDetector-2-1/ADCore/dbd/NDPluginSupport.dbd'" instead.
> Context: file '/corvette/home/epics/devel-3.15/areaDetector-2-1/ADCore/dbd/commonDriverSupport.dbd'
> while reading 'commonDriverSupport.dbd' to create 'simDetectorApp.dbd'
> dbdExpand.pl: Exiting due to errors
> make[3]: *** [../O.Common/simDetectorApp.dbd] Error 255
> Andrew, I don't see any braces in ADCore/ADApp/commonDriverMakefile. Can you tell me what is causing this error in 3.15, while it builds OK in 3.14.12.4?
This has nothing to do with the content of the Makefile, the error is
being reported by the dbdExpand.pl script while it's trying to create
the simDetectorApp.dbd file. I'm not sure what the problem is yet
because I don't have full build of ADCore with all the synApps modules.
It's not necessarily a mismatched brace as the error suggests, that was
just a common cause for the mismatched internal context which is being
reported.
>> perl -CSD /home/h1/EPICS/base/bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../dbd -I/home/h1/EPICS/base/dbd -I/home/h1/EPICS/support/asyn4-25/dbd -I/home/h1/EPICS/support/areaDetector/ADCore/dbd -I/home/h1/EPICS/support/calc-3-4/dbd -I/home/h1/EPICS/support/busy-1-6-1/dbd -I/home/h1/EPICS/support/sscan-2-10/dbd -I/home/h1/EPICS/support/autosave-5-5/dbd -o simDetectorApp.dbd simDetectorSupport.dbd commonDriverSupport.dbd
>> dbdExpand.pl: Leaving context "file '/home/h1/EPICS/support/areaDetector/ADCore/dbd/commonDriverSupport.dbd'", found "file '/home/h1/EPICS/support/areaDetector/ADCore/dbd/NDPluginSupport.dbd'" instead.
>> Context: file '/home/h1/EPICS/support/areaDetector/ADCore/dbd/commonDriverSupport.dbd'
The command is being asked to read in the files simDetectorSupport.dbd
and commonDriverSupport.dbd and to output the fully-expanded result into
the file simDetectorApp.dbd. It is somehow getting confused while doing
that, which is a little strange but the parser does try to keep careful
track of and check its current state.
There are dome debug variables in the Perl code which should help me
track down the problem, but I may not going to be able to get to this
until the end of next week, I'll be away on travel until Thursday.
Heinz: The quickest way for you to continue would be to switch to using
Base-3.14.12.4 (or an earlier 3.14.12 release) instead of 3.15.1, would
that be a possibility? Base-3.15.1 is still fairly new and a lot of
modules have not been built against it yet, so you should be prepared
for a few problems like this if you do need to use it.
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
- RE: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Mooney, Tim M.
- areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Heinz Junkes
- RE: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Mark Rivers
- Re: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Heinz P. Junkes
- Re: areadetector dbExpand.pl error: Braces must be closed in the same file they open in. Andrew Johnson
<2015>
<2015>
