Hi Mark,
I attach 2 reports.
(FYI, I am working with 2 separate IOC apps.
The second being a TCP server that is intended to simulate the I/O behaviour of the pump(s).
I don't currently have access to the 'real' hardware.)
Cheers,
Peter.
-----Original Message-----
Sent: 23 December 2014 02:43
To: Heesterman, Peter J
Cc: EPICS Tech-Talk ([email protected])
Subject: RE: getAddress method behaviour
What does the following show?
asynReport 10 YOUR_PORT_NAME
Sent: Monday, December 22, 2014 9:23 AM
To: Mark Rivers
Hi Mark,
I am passing the former.
BTW, I have configured the IOC with ASYN_MULTIDEVICE, and maxAddr 5.
Cheers,
Peter.
Sent: 22 December 2014 15:21
Subject: Re: getAddress method behaviour
I suspect you are passing the wrong pasynUser to getAddres(). Are you passing the one that was passed into writeInt32 or the pasynUserSelf? You should pass the former.
Sent from my iPhone
On Dec 22, 2014, at 9:12 AM, Heesterman, Peter J <[email protected]<mailto:[email protected]>> wrote:
Hi Mark,
I’m sorry to trouble you.
In my application I am seeking to connect multiple devices (i.e. multiple pumps, in this case).
So, for example, I have record names like:
TURBOSIM:5:WarningTemperature (5 being the last of 5 devices connected).
I had expected asynPortDriver::getAddress to emit the index of the device being addressed (0..4, in this example).
But the only address value I can detect being emitted from the method, is 0 (e.g. when called within readInt32).
I believe it is being invoked with asynUser(s) that are correctly associated with a specific device.
What could I be missing?
Many thanks,
Peter.
TURBOSIM multiDevice:Yes canBlock:Yes autoConnect:Yes
enabled:Yes connected:Yes numberConnects 1
nDevices 1 nQueued 0 blocked:No
asynManagerLock:No synchronousLock:No
exceptionActive:No exceptionUsers 0 exceptionNotifys 0
traceMask:0x1 traceIOMask:0x0 traceInfoMask:0x1
interposeInterfaceList
asynOctet pinterface 0F43E4C8 drvPvt 007F2E08
interfaceList
asynCommon pinterface 0F43D380 drvPvt 007EFAC8
asynDrvUser pinterface 0F43D468 drvPvt 007EFAC8
asynOctet pinterface 0F43D3CC drvPvt 007EFAC8
asynInt32 pinterface 0F43D38C drvPvt 007EFAC8
asynFloat64 pinterface 0F43D3BC drvPvt 007EFAC8
addr 0 autoConnect Yes enabled Yes connected Yes exceptionActive No
exceptionActive No exceptionUsers 0 exceptionNotifys 0
blocked No
Port: TURBOSIM
Timestamp: <undefined>
Input EOS[0]:
Output EOS[0]:
Parameter list 0
Number of parameters is: 10
Parameter 0 type=asynInt32, name=RUNNING, value=1, status=0
Parameter 1 type=asynInt32, name=RESET, value=0, status=0
Parameter 2 type=asynInt32, name=FAULT, value=0, status=0
Parameter 3 type=asynInt32, name=WARNINGTEMPERATURE, value=0, status=0
Parameter 4 type=asynInt32, name=WARNINGHIGHLOAD, value=0, status=0
Parameter 5 type=asynInt32, name=STATORFREQUENCY, value=500, status=0
Parameter 6 type=asynInt32, name=CONVERTERTEMPERATURE, value=50, status=0
Parameter 7 type=asynFloat64, name=MOTORCURRENT, value=10.000000, status=0
Parameter 8 type=asynInt32, name=PUMPTEMPERATURE, value=40, status=0
Parameter 9 type=asynFloat64, name=CIRCUITVOLTAGE, value=30.000000, status=0
Parameter list 1
Parameter list 2
Parameter list 3
Parameter list 4
int32 callback client address=0F3E3510, addr=0, reason=0, userPvt=03685320
int32 callback client address=0F3E3510, addr=0, reason=0, userPvt=03687890
int32 callback client address=0F3E3510, addr=0, reason=0, userPvt=03689E08
int32 callback client address=0F3E3510, addr=0, reason=0, userPvt=0368C378
int32 callback client address=0F3E3510, addr=0, reason=0, userPvt=0368EEA8
int32 callback client address=0F3E2440, addr=0, reason=1, userPvt=0369D768
int32 callback client address=0F3E2440, addr=0, reason=1, userPvt=0369DED8
int32 callback client address=0F3E2440, addr=0, reason=1, userPvt=0369E7E0
int32 callback client address=0F3E2440, addr=0, reason=1, userPvt=0369F0E8
int32 callback client address=0F3E2440, addr=0, reason=1, userPvt=0369F9F0
TURBO multiDevice:Yes canBlock:No autoConnect:Yes
asynOctet pinterface 0F43E4C8 drvPvt 023F0ED8
interfaceList
asynCommon pinterface 0F43D380 drvPvt 023EFAF8
asynDrvUser pinterface 0F43D468 drvPvt 023EFAF8
asynOctet pinterface 0F43D3CC drvPvt 023EFAF8
asynInt32 pinterface 0F43D38C drvPvt 023EFAF8
asynFloat64 pinterface 0F43D3BC drvPvt 023EFAF8
blocked No
Port: TURBO
Input EOS[0]:
Output EOS[0]:
Parameter list 0
Parameter list 1
Parameter list 2
Parameter list 3
Parameter list 4
int32 callback client address=0F3E3510, addr=0, reason=0, userPvt=03735B98
int32 callback client address=0F3E3510, addr=0, reason=0, userPvt=03737410
int32 callback client address=0F3E3510, addr=0, reason=0, userPvt=037386C0
int32 callback client address=0F3E3510, addr=0, reason=0, userPvt=03739970
int32 callback client address=0F3E3510, addr=0, reason=0, userPvt=0373AC20
int32 callback client address=0F3E2440, addr=0, reason=4, userPvt=0373BE30
int32 callback client address=0F3E2440, addr=0, reason=3, userPvt=0373C740
int32 callback client address=0F3E2440, addr=0, reason=4, userPvt=0373D958
int32 callback client address=0F3E2440, addr=0, reason=3, userPvt=0373E268
int32 callback client address=0F3E2440, addr=0, reason=4, userPvt=0373F480
int32 callback client address=0F3E2440, addr=0, reason=3, userPvt=0373FD90
int32 callback client address=0F3E2440, addr=0, reason=4, userPvt=03741568
int32 callback client address=0F3E2440, addr=0, reason=3, userPvt=03741E78
int32 callback client address=0F3E2440, addr=0, reason=4, userPvt=03743090
int32 callback client address=0F3E2440, addr=0, reason=3, userPvt=037439A0
int32 callback client address=0F3E2440, addr=0, reason=6, userPvt=03744AF0
int32 callback client address=0F3E2440, addr=0, reason=8, userPvt=03745C48
int32 callback client address=0F3E2440, addr=0, reason=5, userPvt=03746558
int32 callback client address=0F3E2440, addr=0, reason=6, userPvt=037476A8
int32 callback client address=0F3E2440, addr=0, reason=8, userPvt=03748800
int32 callback client address=0F3E2440, addr=0, reason=5, userPvt=03749110
int32 callback client address=0F3E2440, addr=0, reason=6, userPvt=0374A820
int32 callback client address=0F3E2440, addr=0, reason=8, userPvt=0374B978
int32 callback client address=0F3E2440, addr=0, reason=5, userPvt=0374C288
int32 callback client address=0F3E2440, addr=0, reason=6, userPvt=0374D3D8
int32 callback client address=0F3E2440, addr=0, reason=8, userPvt=0374E530
int32 callback client address=0F3E2440, addr=0, reason=5, userPvt=0374EE40
int32 callback client address=0F3E2440, addr=0, reason=6, userPvt=0374FF90
int32 callback client address=0F3E2440, addr=0, reason=8, userPvt=037510E8
int32 callback client address=0F3E2440, addr=0, reason=5, userPvt=037519F8
float64 callback client address=0F3DBF00, addr=0, reason=9, userPvt=037442B0
float64 callback client address=0F3DBF00, addr=0, reason=7, userPvt=03745408
float64 callback client address=0F3DBF00, addr=0, reason=9, userPvt=03746E68
float64 callback client address=0F3DBF00, addr=0, reason=7, userPvt=03747FC0
float64 callback client address=0F3DBF00, addr=0, reason=9, userPvt=03749FE0
float64 callback client address=0F3DBF00, addr=0, reason=7, userPvt=0374B138
float64 callback client address=0F3DBF00, addr=0, reason=9, userPvt=0374CB98
float64 callback client address=0F3DBF00, addr=0, reason=7, userPvt=0374DCF0
float64 callback client address=0F3DBF00, addr=0, reason=9, userPvt=0374F750
float64 callback client address=0F3DBF00, addr=0, reason=7, userPvt=037508A8
- Re: getAddress method behaviour Pearson, Matthew R.
- RE: getAddress method behaviour Mark Rivers
- getAddress method behaviour Heesterman, Peter J
- Re: getAddress method behaviour Mark Rivers
- RE: getAddress method behaviour Heesterman, Peter J
Bug in 3.14 and 3.15: "*.FLNK is a Channel Access Link ..." Dirk Zimoch
<2014>
<2014>
