I added those environment variables, trace outputs, fixed a missing parenthesis in the original st.cmd, and then recompiled before running. I also disabled the firewall on this mac laptop, just in case that was causing problems. Here now is the output:
#!../../bin/darwin-x86/ps365controlTest
# Setup Environment
< envPaths
epicsEnvSet("ARCH","darwin-x86")
epicsEnvSet("IOC","iocps365controlTest")
epicsEnvSet("TOP","/Users/fdfuller/src/EPICS/myapps/ps365control")
epicsEnvSet("ASYN","/Users/fdfuller/src/EPICS/modules/asyn")
epicsEnvSet("STREAM","/Users/fdfuller/src/EPICS/modules/streams")
epicsEnvSet("EPICS_BASE","/Users/fdfuller/src/EPICS/base")
epicsEnvSet "STREAM_PROTOCOL_PATH" "/Users/fdfuller/src/EPICS/myapps/ps365control/db"
# Allow PV prefixes and serial port name to be set from the environment
epicsEnvSet "P" "ps365control"
epicsEnvSet "R" "Test"
epicsEnvSet "TTY" "/dev/cu.usbserial-FTWDR32T"
# Register all support components
cd /Users/fdfuller/src/EPICS/myapps/ps365control
dbLoadDatabase(dbd/ps365controlTest.dbd)
ps365controlTest_registerRecordDeviceDriver(pdbbase)
# Set up ASYN ports
drvAsynSerialPortConfigure("L0","/dev/cu.usbserial-FTWDR32T",0,0,0) #sets up a port L0 at $TTY (see above)
#now we fill in the details of the port connection
#9600/8/N/1 is the most typical serial port configuration
asynSetOption("L0",0,"baud","9600")
asynSetOption("L0",0,"bits","8")
asynSetOption("L0",0,"parity","none")
asynSetOption("L0",0,"stop","1")
asynSetTraceIOMask("L0",0,2)
asynSetTraceMask("L0",0,255)
## Load record instances
dbLoadRecords("db/devps365control.db","P=ps365control,R=Test,PORT=L0,A=0")
# Start EPICS
cd /Users/fdfuller/src/EPICS/myapps/ps365control/iocBoot/iocps365controlTest
iocInit
Starting iocInit
## EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$
## EPICS Base built Sep 21 2014
2014/12/11 09:46:01.492 L0 addr -1 queueRequest priority 0 not lockHolder
2014/12/11 09:46:01.493 L0 schedule queueRequest timeout
2014/12/11 09:46:01.493 asynManager::portThread port=L0 callback
2014/12/11 09:46:01.493 L0 addr -1 queueRequest priority 0 not lockHolder
2014/12/11 09:46:01.493 /dev/cu.usbserial-FTWDR32T read.
2014/12/11 09:46:01.493 /dev/cu.usbserial-FTWDR32T read 0, return 1
2014/12/11 09:46:01.493 /dev/cu.usbserial-FTWDR32T write.
2014/12/11 09:46:01.493 /dev/cu.usbserial-FTWDR32T write 5
*IDN?
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 49730,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
2014/12/11 09:46:01.494 wrote 5 to /dev/cu.usbserial-FTWDR32T, return asynSuccess
2014/12/11 09:46:01.494 L0 wrote
*IDN?
2014/12/11 09:46:01.494 L0 addr -1 queueRequest priority 0 from lockHolder
2014/12/11 09:46:01.494 L0 schedule queueRequest timeout
2014/12/11 09:46:01.494 asynManager::portThread port=L0 callback
2014/12/11 09:46:01.494 /dev/cu.usbserial-FTWDR32T read.
epics> 2014/12/11 09:46:02.489 /dev/cu.usbserial-FTWDR32T timeout handler.
2014/12/11 09:46:02.594 /dev/cu.usbserial-FTWDR32T read 0, return 1
2014/12/11 09:46:02.594534 L0 ps365controlTestIDN: No reply from device within 1000 ms
2014/12/11 09:46:02.595 asynManager::portThread port=L0 callback
2014/12/11 09:46:02.595 L0 addr -1 queueRequest priority 0 not lockHolder
2014/12/11 09:46:02.595 L0 schedule queueRequest timeout
2014/12/11 09:46:02.595 /dev/cu.usbserial-FTWDR32T read.
2014/12/11 09:46:02.595 /dev/cu.usbserial-FTWDR32T read 0, return 1
2014/12/11 09:46:02.595 /dev/cu.usbserial-FTWDR32T write.
2014/12/11 09:46:02.595 /dev/cu.usbserial-FTWDR32T write 5
*IDN?
2014/12/11 09:46:02.595 wrote 5 to /dev/cu.usbserial-FTWDR32T, return asynSuccess
2014/12/11 09:46:02.595 L0 wrote
*IDN?
2014/12/11 09:46:02.595 L0 addr -1 queueRequest priority 0 from lockHolder
2014/12/11 09:46:03.591 /dev/cu.usbserial-FTWDR32T timeout handler.
2014/12/11 09:46:03.695 /dev/cu.usbserial-FTWDR32T read 0, return 1
2014/12/11 09:46:03.695444 L0 ps365controlTestIDNwf: No reply from device within 1000 ms
So the upshot is that it looks like it's doing something. The downside is: I don't know why it isn't receiving a response. As I said, if you manually send values to /dev/cu.usbserial-FTWDR32T, such as the *IDN? command that it's trying, you get a response. I tested other commands and full control is possible.
Still reading this streamDevice documentation to figure out where I can add some communication timeout time. Not sure that's the issue anymore, now that I see this trace output.
