1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Darwin SHRLIB_VERSION build error: multiple target patterns
To: [email protected]
Date: Thu, 11 Dec 2014 09:33:25 -0600
On 12/10/14 5:31 PM, Andrew Johnson wrote:
> Use SHRLIB_VERSION = 0.1.0 (not +=) as you want to replace the current
> value; on most architectures that variable is empty so the two have
> the same effect, but due to a bug in the Darwin CONFIG files it gets
> set to the Base version number even when you're not building Base.
Hi, Andrew.
Bingo!  That worked.  Thanks!
FYI, I was just going off of what the Application Developer's Guide says
in section 4.6.13.8, "Specifying shared library version number":
  A library version number can be specified when creating a shared
  library as follows:
  SHRLIB_VERSION += <version>
So, probably that should be changed to just "=" (not "+=")?
Lewis
Darwin SHRLIB_VERSION build error: multiple target patterns J. Lewis Muir
Re: Darwin SHRLIB_VERSION build error: multiple target patterns Andrew Johnson
Prev: RE: Changing the Timeout for drvAsynSerialPort? Mark Rivers
Next: Re: read status nin "" 0 error with Ana Malagon
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Darwin SHRLIB_VERSION build error: multiple target patterns Andrew Johnson
Next: Changing the Timeout for drvAsynSerialPort? Franklin Fuller
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
