1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Changing the Timeout for drvAsynSerialPort?
To: [email protected]
Date: Wed, 10 Dec 2014 17:47:25 -0800
Hi all,
Question is: How can I changed the timeout for drvAsynSerialPort?
Context follows (maybe I'm asking the wrong question):
I've been working through a tutorial* with few modifications.  So far no problems until I try to initiate communication with a Stanford Research Systems PS365 HV supply.  When I run ./st.cmd, everything says it initializes, but then I get a message saying that the ioc did not receive a response within 1 second.  The exact error(s) are:
2014/12/10 17:31:18.937952 L0 ps365controlTestIDN: No reply from device within 1000 ms
2014/12/10 17:31:20.039439 L0 ps365controlTestIDNwf: No reply from device within 1000 ms
Further, if I query the ioc with "caget -S ps365controlTestIDNwf", I get this:
ps365controlTestIDNwf \003
CA.Client.Exception...............................................
    Warning: "Identical process variable names on multiple servers"
    Context: "Channel: "ps365controlTestIDNwf", Connecting to: 198.128.196.226:5064, Ignored: franklins-mbp.dhcp.lbl.gov:5064"
    Source File: ../cac.cpp line 1298
    Current Time: Wed Dec 10 2014 17:44:31.920218000
I can "manually" communicate with the device using a simple screen command.  I use the same port address with 9660/8/N/1 standard settings. It seems to take a second, maybe 2, to open the connection.  So my thought was that maybe I just need to have the asyn driver increase its timeout time to avoid this error.
I can't see a way to change the timeout, however.
My st.cmd is given below:
#!../../bin/darwin-x86/ps365controlTest
# Setup Environment
< envPaths
epicsEnvSet "STREAM_PROTOCOL_PATH" "$(TOP)/db"
# Allow PV prefixes and serial port name to be set from the environment
epicsEnvSet "P" "$(P=ps365control)"
epicsEnvSet "R" "$(R=Test)"
epicsEnvSet "TTY" "$(TTY=/dev/ttyUSB)"
# Register all support components
cd ${TOP}
dbLoadDatabase(dbd/ps365controlTest.dbd)
ps365controlTest_registerRecordDeviceDriver(pdbbase)
# Set up ASYN ports
drvAsynSerialPortConfigure("L0","$(TTY)",0,0,0) #sets up a port L0 at $TTY (see above)
#now we fill in the details of the port connection
#9600/8/N/1 is the most typical serial port configuration
asynSetOption("L0",-1,"baud","9600"
asynSetOption("L0",-1,"bits","8")
asynSetOption("L0",-1,"parity","none")
asynSetOption("L0",-1,"stop","1")
asynSetOption("L0",-1,"clocal","Y")
asynSetOption("L0",-1,"crtscts","N")
## Load record instances
dbLoadRecords("db/devps365control.db","P=$(P),R=$(R),PORT=L0,A=0")
# Start EPICS
cd ${TOP}/iocBoot/${IOC}
Re: Changing the Timeout for drvAsynSerialPort? Eric Norum
RE: Changing the Timeout for drvAsynSerialPort? Mark Rivers
Re: Changing the Timeout for drvAsynSerialPort? Dirk Zimoch
Prev: RE: Different behavior on dbdToRecordTypeH - include guard Kim, Kukhee
Next: Re: Changing the Timeout for drvAsynSerialPort? Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Darwin SHRLIB_VERSION build error: multiple target patterns J. Lewis Muir
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
