If you made that modification then libandor.so and libandor.so.2 should not have ended up in ADAndor/lib/linux-x86_64. Perhaps you did not do a "make uninstall" at the ADAndor top-level after making your change?
-----Original Message-----
Sent: Wednesday, December 03, 2014 1:16 PM
To: Mark Rivers; [email protected]
Subject: Re: Area Detector and Andor
Right, that is what I did in the "modified" version of the AD module.
Thanks Mark,
Zen
On 12/03/14 11:09, Mark Rivers wrote:
> It sounds like you need to just comment out these lines in ADAndor/andorSupport/Makefile as I have done below:
> else ifeq (linux-x86_64, $(findstring linux-x86_64, $(T_A)))
> #LIB_INSTALLS_Linux += ../os/linux-x86_64/libandor.so.2
> Then these files will not be installed into ADAndor/lib/linux-x86_64
> Mark
> From: Zenon Szalata [mailto:[email protected]]
> Sent: Wednesday, December 03, 2014 12:59 PM
> Hi Mark,
> I need to put a bit more effort into understanding what is going on when
> I use AD 2.1.
> This is the contents of:
> zms@esaanal2 $ ll ADAndor/lib/linux-x86_64/
> total 5537
> drwxr-xr-x 2 mdunning ar 2048 Nov 22 10:33 ./
> drwxr-xr-x 3 mdunning ar 2048 Nov 7 20:41 ../
> -r--r--r-- 1 mdunning ar 2645945 Nov 7 20:41 libandor.so
> -r--r--r-- 1 mdunning ar 2645945 Nov 7 20:41 libandor.so.2
> -r--r--r-- 1 mdunning ar 213304 Nov 22 10:33 libandorCCD.a
> -r-xr-xr-x 1 mdunning ar 159262 Nov 22 10:33 libandorCCD.so*
> Before building the Andor IOC, I remove both libandor.so and
> libandor.so.2. This works for the case of AD 1.8 and 1.9.1.
> Anyway, I will dig a bit deeper into the code to see why the AD 2.1 is
> not working for us.
> BTW, AD 2.1 works fine with our Prosilica cameras.
> Thanks,
> Zen
> On 12/03/14 10:40, Mark Rivers wrote:
>> Hi Zen,
>>> One more problem remains. This fix works with AD 1.8 and 1.9.1 but not
>>> with 2.1.
>>> The IOC built with AD 2.1, still exhibits the same problem, all seems to
>>> work except for getting the image data. I wonder if there is another
>>> level if mismatch between AD 2.1 and our SDK?
>> I did not change the Andor linux-x86_64 libraries between 1.8 and 2.1. They are all 2.84.
>> I did upgrade to 2.98 for the upcoming 2.2 release.
>> Commenting out the install in the andorSupport directory is fine. Alternatively I think you can add a line to your Makefile that tells it where to find the libandor.so file, probably andor_DIR=/usr/local or something.
>> I cannot explain why it would not work for you with 2.1 since I did not update the library, and in any event you should not be installing the library that comes with ADAndor anyway.
>> What is the contents of ADAndor/lib/linux-x86_64?
>> Mark
>> Sent: Wednesday, December 03, 2014 12:20 PM
>> Subject: Area Detector and Andor
>> Hi Mark,
>> I returned to our Andor problem and now I mostly understand what is
>> going wrong.
>> It turns out that the libandor.so library which comes with the Area
>> Detector package does not work with our version of the Andor SDK, which
>> is version 2.94. Building Area Detector package puts libandor.so in
>> lib/linux-86_64, the IOC when built, links to the library in Area
>> Detector, and when started, loads this library and the IOC almost works
>> with the exception that no image data are received from the camera.
>> If I remove the libandor.so library from the Area Detector, build my IOC
>> it links to the libandor.so library in the locally installed SDK
>> package. When I start the IOC it loads the SDK library and everything
>> works; the image data are received from the camera.
>> Presently we have AD version 1.8, 1.9.1, and 2.1 installed. I have
>> modified a Makefile in the andorSupport directory not to install the
>> andor libraries. I am not sure if this is the correct way to deal with
>> our problem.
>> with 2.1.
>> Thanks,
>> Zen
- Re: Area Detector and Andor Zenon Szalata
- Area Detector and Andor Zenon Szalata
- RE: Area Detector and Andor Mark Rivers
RE: FW: EPICS 3.15.1 Dudley, David
RE: FW: EPICS 3.15.1 Mooney, Tim M.
<2014>
<2014>
