One thing I might also suggest might be a way to specify a separate INSTALL_LOCATION for test programs.
That way, a test program for a particular module doesn't necessarily need to go into the <TOP>/bin directory, but perhaps might go into another 'specialized' location.
Later-
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Tel. 517-908-7133
Email: [email protected]
-----Original Message-----
Sent: Wednesday, December 03, 2014 2:05 PM
To: Dudley, David; EPICS Tech-Talk
Subject: RE: FW: EPICS 3.15.1
The convention used at Diamond, which has been adopted for areaDetector (R2-0 onward) is the following, using the Andor detector as an example:
ADAndor
configure/ Configuration files for building the library
andorApp
src/ Library source
Db/ Database files
op/
adl/ medm files
edl/ edm files
andorSupport Vendor provided files
os
linux-x86 Vendor library for 32-bit Linux
win32-x86 Vendor library for 32-bit Windows
documentation/ Always helpful
iocs/
andorIOC/ Example IOC application
configure/ Configuration file for the example IOC
andorApp/
src/ Source code for example application
iocBoot/
iocAndor/ Example IOC boot directory
ADAndor/configure/RELEASE only includes the dependencies required to build the library
ADAndor/iocs/andorIOC/configure/RELEASE includes all of the dependencies to build the example application, i.e. some synApps modules.
There is a flag in ADAndor/configure/CONFIG_SITE that controls whether the ADAndor/iocs directory gets built at all. This allows one to build only the library, and not even have the synApps modules present.
From: [email protected] [mailto:[email protected]] On Behalf Of Dudley, David
Sent: Wednesday, December 03, 2014 10:41 AM
To: EPICS Tech-Talk
Have to agree with Ralph on that point.
Support modules may build (and probably -should- build) test programs to insure they operate correctly, but I don't see why those should be built as a part of the library. Separating the library from the test program would seem to make sense to me, as the process to create the actual test program now becomes exactly the same as the process used to create an IOC using that module.
Seems a better way to separate functions, to me.
I'll add 0.5ct to Ralphs suggestion....
David Dudley
640 South Shaw Lane
Tel. 517-908-7133
From: [email protected] [mailto:[email protected]] On Behalf Of Ralph Lange
Sent: Wednesday, December 03, 2014 10:59 AM
To: EPICS Tech-Talk
Subject: Re: FW: EPICS 3.15.1
While we're at it...
On 03/12/2014 16:44, Mooney, Tim M. wrote:
> For any synApps module, you should include <module>Support.dbd, and not <module>.dbd, because <module>.dbd is what the module builds for its own use, while <module>Support.dbd is what it builds for export to other modules. For autosave, the names are as.dbd and asSupport.dbd.
This is indeed the synApps model of naming things, but synApps is a bit special in this regard.
The more common pattern is to have <module> export <module>.dbd for inclusion by applications, and I would lean towards proposing synApps make a step in that direction.
What is "its own use" for a support module anyway? By definition, a support module provides a library and resource files (like dbd files and db templates) that go with it. Tests and examples should rather be moved into embedded self-contained TOP structures - 3.15 provides convenient Makefile rules to do that. This has multiple advantages: it clearly separates support module and example code (inexperienced users usually can't tell which is which in the existing mixed modules, and create worse applications as a result), and it allows simply copying out the complete embedded example tree into their own work area (requiring only a change in the configure/RELEASE file to locally build a correct full example app).
Just my 2.5ct...
~Ralph
- EPICS 3.15.1 Dudley, David
- FW: EPICS 3.15.1 Dudley, David
- RE: FW: EPICS 3.15.1 Dudley, David
- Re: FW: EPICS 3.15.1 Michael Davidsaver
- RE: FW: EPICS 3.15.1 Mooney, Tim M.
Re: Area Detector and Andor Zenon Szalata
RE: Area Detector and Andor Mark Rivers
<2014>
RE: FW: EPICS 3.15.1 Mark Rivers
<2014>
