1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Create two channels on same PV name in same CA context?
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 03 Dec 2014 11:32:09 -0600
Hello, Tech-Talkers.
Is it possible, using the EPICS Base 3.14 CA client library, to create
two identical CA channels by calling ca_create_channel() twice on the
same PV name in the same CA context?
It's looking like the answer is no, but I thought I'd ask to be sure.
Lewis
Re: Create two channels on same PV name in same CA context? Andrew Johnson
Prev: RE: FW: EPICS 3.15.1 Dudley, David
Next: Re: Create two channels on same PV name in same CA context? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: EPICS 3.15.1 Dudley, David
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
