OK, thanks.
I added the support back in to the current version of EDM and it seems
to work fine for us.
It seems such a handy widget. Surprised that no one else uses it.
On 12/01/2014 03:14 PM, Kasemir, Kay wrote:
Hi:
I had added some string chart widget to EDM way back, it had very little use here at the SNS.
I assume John had to remove it because it had some problems and nobody missed it so far.
If you were happy with it, and you can get the older code to compile, you're more than welcome to add it back into your copy of EDM.
Kay
On Dec 1, 2014, at 10:58 AM, Mike Westfall <[email protected]>
wrote:
A question probably best answered by Kay Kasemir:
It seems that StripClass support in pvFactory has been removed from the latest versions of EDM.
Was there a particular reason for this?
What do I risk by adding it back in?
Mike Westfall
Gemini Observatory
Colina El Pino S/N, Casilla 603
La Serena, Chile
Tel: +56 51 2205625
- RE: Strip Chart widget in EDM Sinclair, John William
- Strip Chart widget in EDM Mike Westfall
Using EPICS with Attocube stepper motor Ana Malagon
EPICS 3.15.1 Dudley, David
<2014>
<2014>
