1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: MBBI Value Type
To: "'Elmer Pensack'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 25 Nov 2014 18:46:25 +0000
The data type of the ZRVL field is ULONG:
This is from mbbiRecord.dbd for 3.14.12.4:
        field(ZRVL,DBF_ULONG) {
                prompt("Zero Value")
                promptgroup(GUI_BITS1)
                special(SPC_MOD)
                pp(TRUE)
                base(HEX)
                interest(1)
However, because Channel Access does not support a ULONG datatype, it promotes it to double.
From: [email protected] [mailto:[email protected]] On Behalf Of Elmer Pensack
Sent: Tuesday, November 25, 2014 12:14 PM
To: [email protected]
Subject: MBBI Value Type
In working with the value types of a MBBI, I noticed that the native type of the mbbi values is DBF_DOUBLE even though the documentation states ULONG. When a connection handler completes a connection with those attributes it returns the DOUBLE type.  Also, when a caget with the –D option is executed the following is displayed.
>  caget –d DBR_LONG <PV NAME>.ZRVL
<PV NAME>.ZRVL
     Native Data Type:     DBF_DOUBLE
     Request Type:         DBR_LONG
     Element Count:        1
     Value:                0
However a caput with a double value does get truncated during the put.  Which makes sense as these values should be integers. So why is the native type a double?  Currently I am basing display of data by the EPICS type.  So this data is shows as a decimal value because it comes back as a DOUBLE.
We can code for this configuration but I was just curious as why the native type for MBBI values was set to DOUBLE.
Thanks
MBBI Value Type Elmer Pensack
Prev: MBBI Value Type Elmer Pensack
Next: Re: CSS/BOY: how to force a Scaled Slider to rescale when the PV rescales Peter Milne
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: edm questions Mark Rivers
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
