On 11/24/2014 02:48 AM, [email protected] wrote:
> Interesting. I know I'd convinced myself some time ago that DBF_CHAR was
> unsigned, but I guess that was by inspecting some code ... and it looks
> as if different corners of EPICS do this differently. Certainly where I
> looked I found the following mappings:
> CHAR 8-bit unsigned
> SHORT 16-bit signed
> LONG 32-bit signed
> ENUM 16-bit unsigned (plus the strings)
> STRING 40 8-bit bytes (indeterminate sign? haven't checked)
> FLOAT 32-bit floating point
> DOUBLE 64-bit floating point
> That is, as I understand it, the complete list of transportable EPICS CA
> datatypes.
That looks correct. The STRING representation uses the native char of
the client's ABI, so the characters may be signed or unsigned.
> However it sounds as if things aren't as well defined as I thought.
Inside the IOC database we use a wider set of types and different (and
incompatible) definitions for the field index enum values DBF_STRING,
DBF_CHAR etc.
> Is it worth digging deeper into the definitions of these types? I
> don't remember where I got the list above, but my understanding was
> that it was definitive ... but you're saying that things are not so clear.
The CA client data types are defined in db_access.h, while the IOC's
types are in dbFldTypes.h. I don't have time to explain the history of
this split right now...
>> I will be introducing two 64-bit integer field types into the IOC
>> database on the 3.16 branch which will require changes to some external
>> software (the new DBF_INT64 and DBF_UINT64 values appear in the middle
>> of the enum dbfType range, they can't be appended to it). I could take
>> that opportunity to try fixing some of these other type issues as well
>> if the community wants that and is willing to accept more breakage.
>> This work would not affect CA clients though, I am not going to be
>> touching that protocol or the db_access.h types which are used by
>> clients.
> If you're not changing CA how do you propose to transport 64-bit
> integers? Without CA support I don't think I understand your proposal.
The V4 pvAccess protocol can transport 64-bit integer values, so this
will eventually allow them to be passed over the network natively. For
CA the DBF_INT64 and DBF_UINT64 field types will appear as DBF_DOUBLE
and automatically converted, just like DBF_ULONG fields are currently
represented.
If someone wants to look at adding 64-bit support to CA they can of
course do that, but I don't think it'll be easy [Required: Maintain
compatibility with older CA client/servers; modify both RSRV + CAS
servers; modify PV Gateway as well] and I suspect is not be worth doing
at all.
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
- RE: Small bug in caget michael.abbott
- Small bug in caget michael.abbott
- Re: Small bug in caget Andrew Johnson
Re: streamDevice output format question Maren Purves
RE: streamDevice output format question peter.owens
<2014>
<2014>
