1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: rebootHookAdd() equivalent for OSI / RTEMS?
To: [email protected]
Date: Mon, 24 Nov 2014 13:35:33 -0500
epicsAtExit() from epicsExit.h is the first thing to try.
On 11/24/2014 12:59 PM, Mike Westfall wrote:
> We have a reflective memory card (VMI5588) where we call the vxWorks
> function rebootHookAdd() to hook a routine to disable interrupts for the
> card in the event of a soft reboot.
> We are converting to RTEMS, and I am wondering if there is an equivalent
> call in the OSI layer, or if we will have to resort to the
> RTEMS-specific atexit() to hook the routine?
> I see that Eric Bjo. had the same question several years ago, but I
> don't know if the situation is still the same since then. I suspect it
> is, but perhaps someone can give me some good news on this front...
rebootHookAdd() equivalent for OSI / RTEMS? Mike Westfall
Prev: rebootHookAdd() equivalent for OSI / RTEMS? Mike Westfall
Next: Re: rebootHookAdd() equivalent for OSI / RTEMS? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
