Hi Martin,
This is because you are using a new version of the sequencer that breaks backwards compatibility in C functions that use seq_pvPut and seqPvGet.
I have not tried 2.2.0.2.
The last tech-talk message on this topic that I could find was this one:
http://www.aps.anl.gov/epics/tech-talk/2014/msg01408.php
As I read that Ben was considering rolling back the breaking incompatibilities, so we have not modified the motor code to use the new syntax.
Can you roll back to a previous release of the sequencer?
-----Original Message-----
Sent: Monday, November 24, 2014 10:36 AM
To: Mark Rivers
Cc: [email protected]
Subject: Motion Controller for Newport XPS q8 installation
Hey Mark,
i tried and failed to compile your motion controller R6-8-1.
I tried on two different PCs with different systems without any success.
First OS: Ubuntu 14.04.1 LTS
Compiler: gcc 4.8.2
Second OS: Fedora release 20 (Heisenbug)
Compiler: gcc 4.8.3 20140911
On both systems the following software/modules are installed:
-EPICS base-3.14.12.4
-asyn4-24
-busy-1-6-1
-ipac-2.11
-seq-2.2.0.2
The compiler shows following:
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -Wno-write-strings -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/sauter/epics/asyn/include -I/home/sauter/epics/seq/include -I/home/sauter/epics/base/include/os/Linux -I/home/sauter/epics/base/include -I/home/sauter/epics/ipac/include MM4005_trajectoryScan.c
../MM4005_trajectoryScan.st: In function 'seqg_action_trajectoryScan_0_execute':
../MM4005_trajectoryScan.st:384:40: error: called object is not a function or function pointer
startTime = time(0);
../MM4005_trajectoryScan.st: In function 'seqg_action_trajectoryScan_0_wait_execute':
../MM4005_trajectoryScan.st:425:31: error: called object is not a function or function pointer
if (difftime(time(0), startTime) > expectedTime*timeScale*2.) {
../MM4005_trajectoryScan.st: In function 'getEpicsMotorMoving':
../MM4005_trajectoryScan.st:645:9: error: too few arguments to function 'seq_pvGet'
seq_pvGet(ssId, pVar->epicsMotorDoneIndex[j], 0);
In file included from /home/sauter/epics/seq/include/seq_snc.h:30:0,
from MM4005_trajectoryScan.c:7:
/home/sauter/epics/seq/include/seqCom.h:76:23: note: declared here
epicsShareFunc pvStat seq_pvGet(SS_ID, CH_ID, enum compType, double tmo);
../MM4005_trajectoryScan.st: In function 'waitEpicsMotors':
../MM4005_trajectoryScan.st:665:13: error: too few arguments to function 'seq_pvPut'
seq_pvPut(ssId, pVar->motorCurrentIndex[j], 0);
/home/sauter/epics/seq/include/seqCom.h:79:23: note: declared here
epicsShareFunc pvStat seq_pvPut(SS_ID, CH_ID, enum compType, double tmo);
../MM4005_trajectoryScan.st:671:9: error: too few arguments to function 'seq_pvPut'
make[3]: *** [MM4005_trajectoryScan.o] Error 1
make[3]: Leaving directory `/home/sauter/epics/motorR6-8-1/motorApp/NewportSrc/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/home/sauter/epics/motorR6-8-1/motorApp/NewportSrc'
make[1]: *** [NewportSrc.install] Error 2
make[1]: Leaving directory `/home/sauter/epics/motorR6-8-1/motorApp'
make: *** [motorApp.install] Error 2
I'm looking forward for your advice
sincerely
Martin
- Motion Controller for Newport XPS q8 installation uadly
rebootHookAdd() equivalent for OSI / RTEMS? Mike Westfall
<2014>
<2014>
