Hi Zen,
When you say "we can't acquire images" what do you mean?
- Does the frame counter in the main display increment?
- Have you enabled ArrayCallbacks in the main display?
- If so, then if you enable a statistics plugin is it getting callbacks?
- If so, are the statistics non-zero?
- If your problem is just not seeing images in a client like ImageJ, have you set EPICS_CA_MAX_ARRAY_BYTES correctly?
The obvious question is what might have changed a week or so ago? Has the areaDetector software been rebuilt? Have there been OS upgrades?
-----Original Message-----
Sent: Monday, November 17, 2014 5:30 PM
To: Mark Rivers; [email protected]
Subject: Andor - Area Detector
Hi Mark,
Something inexplicable is going on with our two Andor DO420A-BN-995
cameras. All was working well until a week ago or so. Since change
took place, The Area Detector based IOC starts up without errors,
connects to the camera, the EDM screen shows correct values obtained
from the camera, and we can't acquire images. I have setup one of these
cameras in my office, I give it an external trigger, no image, changing
the trigger mode to internal results in the same, no image data. We are
using Andor SDK V2.94, Epics R3.14.12.2, asyn R4.20, ...
I have attached a console output file, which includes trace data.
I have build a few of the examples in the SDK package. One of these is
image test program. It generates a reasonable image file.
We also built a copy of this IOC with Epics R3.14.12.4, asyn 4.23, CALC
3.0, busy 1.6, sscan 2.9, mca 7.4, and area detector 1.9.1. This build
behaves identically as the older version.
Can you suggest how to proceed understanding and fixing this problem?
Thank you in advance,
Zen
- Re: Andor - Area Detector Zenon Szalata
- Andor - Area Detector Zenon Szalata
<2014>
<2014>
