Hi Vikram,
If you want to pass a mask to the mbbi record you must use the asynUInt32Digital device support, not asynInt32.
Your message only had a 3-lines from the asynDriver manual. Here is a more complete section
The support uses the following conventions for DTYP and INP. OUT fields are the same as INP.
field(DTYP,"asynXXX")
field(INP,"@asyn(portName,addr,timeout)drvParams")
or
field(INP,"@asynMask(portName,addr,mask,timeout)drvParams")
where
XXX - The name of the type of interface supported.
portName - The name of the port.
addr - The address. If addr is not specified the default is 0.
mask - This is for devAsynUInt32Digital. It is also used by devAsynInt32 to specify the number of bits of the hardware device for drivers that do not support getBounds().
timeout - The timeout value for asynUser.timeout. If not specified the default is 1.0.
drvParams - This is passed to the low level driver via the asynDrvUser interface. It is optional.
Note that for “mask” it says:
“It is also used by devAsynInt32 to specify the number of bits of the hardware device for drivers that do not support getBounds().”
So the purpose of the “mask” parameter in devAsynInt32 is different from the use in the devAsynUInt32Digital. For asynInt32 it is intended to be used for drivers than cannot know
how many bits a device like an A/D or D/A converter has, and so cannot implement the asynInt32::getBounds() function. The Modbus driver is an example, since it is generic and cannot know what type of A/D or D/A is in use at a particular Modbus address.
For masking bits with the mbbo or mbbi record you should use the asynUInt32Digital interface and device support.
However, I do not understand why you got the error message you did. I just tested it, and it actually let me use the asynMask notation with the asynInt32 interface with no error
message. Here is the output of dbpr on such a record:
epics> dbpr 13SIM1:cam1:SimMode_RBV 10
ACKS: NO_ALARM ACKT: YES ASG: ASP: (nil)
BKPT: 00 COSV: NO_ALARM DESC: DISA: 0
DISP: 0 DISS: NO_ALARM DISV: 1 DPVT: 0x958cd28
DSET: 0x85bdc7c DTYP: asynInt32 EIST: EISV: NO_ALARM
EIVL: 0x0 ELST: ELSV: NO_ALARM ELVL: 0x0
EVNT: 0 FFST: FFSV: NO_ALARM FFVL: 0x0
FLNK:CONSTANT 0 FRST: FRSV: NO_ALARM FRVL: 0x0
FTST: FTSV: NO_ALARM FTVL: 0x0 FVST:
FVSV: NO_ALARM FVVL: 0x0
INP:INST_IO @asynMask(SIM1,0,12,1)SIM_MODE LALM: 1
LCNT: 0 LSET: 0x960d9c8 MASK: 4294967295
MLIS: 00 00 00 00 00 00 00 00 00 00 00 00 MLOK: 18 b9 13 09
MLST: 1 NAME: 13SIM1:cam1:SimMode_RBV NIST:
NISV: NO_ALARM NIVL: 0x0 NOBT: 0 NSEV: NO_ALARM
NSTA: NO_ALARM ONST: Peaks ONSV: NO_ALARM ONVL: 0x1
ORAW: 1 PACT: 0 PHAS: 0 PINI: NO
PPN: (nil) PPNR: (nil) PRIO: LOW PROC: 0
PUTF: 0 RDES: 0x8e01738 RPRO: 0 RSET: 0x85be860
RVAL: 1 SCAN: I/O Intr SDEF: 1 SDIS:CONSTANT
SEVR: NO_ALARM SHFT: 0 SIML:CONSTANT SIMM: NO
SIMS: NO_ALARM SIOL:CONSTANT SPVT: 0x97115b8 STAT: NO_ALARM
SVAL: 0 SVST: SVSV: NO_ALARM SVVL: 0x0
SXST: SXSV: NO_ALARM SXVL: 0x0 TEST:
TESV: NO_ALARM TEVL: 0x0 THST: THSV: NO_ALARM
THVL: 0x0 TIME: 2014-11-17 15:19:03.041359713 TPRO: 0
TSE: 0 TSEL:CONSTANT TTST: TTSV: NO_ALARM
TTVL: 0x0 TVST: TVSV: NO_ALARM TVVL: 0x0
TWST: TWSV: NO_ALARM TWVL: 0x0 UDF: 0
UNSV: NO_ALARM VAL: 1 ZRST: LinearRamp ZRSV: NO_ALARM
ZRVL: 0x0
Note that the INP field is “INST_IO @asynMask(SIM1,0,12,1)SIM_MODE” and the DTYP field is “asynInt32”. I did not get any error when booting the IOC or changing the record. However,
in this case the mask will be ignored, the devAsynInt32 device support ignores the mask for mbbi and mbbo records.
I suspect you are getting the error message because parseLink put that message in your pasynUser->errorMessage field, and it was never printed (because the parseLink message is not
really an error in this case). Sometime later your driver produced an error but did not replace pasynUser->errorMessage, so you ended up with a bogus error message.
How to possible pass mask with asynInt32 interface?
I am using asynInt32 interface for mbbi record.
As explain in asynDriver manaul, we can use
field(INP,"@asyn(portName,addr,timeout) drvParams")
or
field(INP,"@asynMask(portName,addr,nbits,timeout) drvParams")
for asynInt32 device support.
But when i am using " asynMask" for INP it gives an error " devAsynInt32 process read error invalid INST_IO Must be asyn(<port> <addr> <timeout>)userParams
" on the IOC shell.
