Tong Zhang,
I can certainly help you.
Difficult to say what exactly is the problem without the error message.
To start, I would just guess that you environment is not set correctly.
Are you on Linux?
Note that QtDM requires a few environment variables to be set to start and run correctly.
What are your settings for QTDM_LIBINSTALL, QTDM_RPATH, and LD_LIBRARY_PATH?
In the tutorial you are following, my installation paths were
/home/local/epics # Home directory of the epics user
+-- base
+-- <base.version> # Base version is 3.14.12.4
+-- bin/linux-x86_64
+-- lib/linux-x86_64
+-- extensions
+-- <base.version> # Extensions compiled against this base version
+-- src # Where the source for EPICS extensions is installed
+-- bin/linux-x86_64 # Where the extension binary files are installed
+-- extras # Non-EPICS base and non-EPICS extensions
+-- <base.version> # Version the source was compiled against
+-- bin/linux-x86_64 # Where the binary files are installed
In the tutorial, I installed caQtDM in the extras/... directories as it is not
an EPICS extension (i.e. doesn't use the configure directory which is part of
the EPICS build system)
I hope this help.
If it doesn't, send the error message and the first few lines of
./caQtDM_BuildAll
Emmanuel Mayssat
http://www.epicsqt.org
> Date: Fri, 14 Nov 2014 14:44:18 +0800
> From:
[email protected]> To:
[email protected]> Subject: compile qtdm
> Hi Emayssat,
> I came cross your caQtDM wiki page, it is really a great job. I'm
> working on the development for FEL facility control applications, and I
> have experience about C++/QT, so your qtdm is a nice tool for me to
> choose. However, I failed to compile the source, is complains the
> qtcontrols lib when linking, my qt version is 4.8.6, could you please
> help me out?
> Thanks!
> Tong Zhang
> Free-electron Laser Department,
> Shanghai Institute of Applied Physics (SINAP), CAS
> 2019 Jialuo Road, Shanghai 201800, China
> Office: +86-021-3919-4269
