Look at the operations that can be done in a CALC record. There is a C "?" operation. You can use that as an if/then/else to get the condition. YOu can use an output record to stop
the loop from running - or a disable of the root record.
How to perform "for loop" in VDCT?
I want to try this program in VDCT .
float avg;
int sum=0;int i,j;
for (i=0;i<20;i++)
for(j=0;j<10;j++)
if(j%2==0)
sum=sum+100;
else
diff=-100;
avg=(sum+diff)/10;
printf("%f",avg);
what type of record and field is used for this program in VDCT?
please provide me solution?
Thanks in advance......
- How to perform Loop in VDCT priya tiwari
autosave fdbrestore Pearson, Matthew R.
<2014>
RE: How to perform Loop in VDCT Mooney, Tim M.
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
