> The funny thing now is that imageJ opens a white canvas. As soon as I open the brightness dialogue the image is how fine.
That is normal behavior with 16-bit images. For some reason ImageJ always gets the initial brightness and contrast wrong for 16-bit images. But as you said if you open the brightness dialog (Control+Shift+C) it then displays OK.
-----Original Message-----
Sent: Monday, November 10, 2014 9:23 AM
To: Mark Rivers; [email protected]
Subject: Re: areaDetector and ADRoper; view files in imageJ
Dear Mark,
Thanks. It was my fault because a typo in this environment variable.
Thanks.
Zunbeltz
al., 2014.eko azaren 10a 13:50(e)an, Mark Rivers igorleak idatzi zuen:
> Hi Zunbeltz,
> Have you looked at the Troubleshooting section in the areaDetector Viewers documentation?
> http://cars.uchicago.edu/software/epics/areaDetectorViewers.html#Troubleshooting
> The EPICS areaDetector ImageJ viewer creates a diagnostic log window that probably has error messages in it.
> I suspect that your problem is that you need to set the environment variable EPICS_CA_MAX_ARRAY_BYTES to a value that is at least as large as the biggest image you want to transport over Channel Access. In your screen shots the images are 1024x1024 16-bit. That means EPICS_CA_MAX_ARRAY_BYTES needs to be at least 2MB=20897152. I would recommend setting it to 10000000 in case you use some larger cameras as well.
> The EPICS_CA_MAX_ARRAY_BYTES environment variable needs to be set on both the Windows machine running the EPICS IOC and on the client machine that is running ImageJ.
> Mark
> From: [email protected] [[email protected]] on behalf of zunbeltz [[email protected]]
> Sent: Monday, November 10, 2014 4:58 AM
> To: [email protected]
> Subject: areaDetector and ADRoper; view files in imageJ
> Dear all,
> I got running areaDetector with a PI-MAX camera using the ADRoper driver.
> In my setup the camera is controlled by the ioc server in a windows machine.
> Use MEMD to acquire the photos from a remote linux machine.
> I manage to connect imagej to the acquired image; but it is completely
> black ( all the bytes 0).
> The configuration used can be seen in the attached fiels.
> I try to change the file format from SPE to TIFF (16 bit and 8 bit) but
> I always get a 16 bit black image in imageJ.
> (I have installed the SPE plugin).
> Any idea where can I look?
> Best regards,
> Zunbeltz
> Dr. Zunbeltz Izaola
> Accelerator Physics Group
> ESS-Bilbao
Dr. Zunbeltz Izaola
ESS-Bilbao
- areaDetector and ADRoper; view files in imageJ zunbeltz
- RE: areaDetector and ADRoper; view files in imageJ Mark Rivers
- Re: areaDetector and ADRoper; view files in imageJ zunbeltz
Browser based EPICS GUI Alex Wallace
<2014>
<2014>
