double foo[7];
size_t s = sizeof foo;
An almost any machine architecture now in use it is expected that s would be 56 — 7 elements, 8 bytes each.
Also — is the code below an accurate copy? The if statement contains an assignment, not a conditional.
> On Nov 7, 2014, at 9:02 AM, Brown, David L. <[email protected]> wrote:
> Hi, all,
> I got around the problem. I don’t know why this is, but when one defines
> an array size of 7 elements (like as seen below), assigns them to an array
> of three elements outside the state machine, and then reassigns the
> elements inside the state machine, there is no core dump. I also looked
> at the size of the array MPS and it said that my array was a size of 56 as
> opposed to the 7 elements I defined. I have convinced myself that this
> was a memory allocation problem as the array size (as interpreted by the
> state machine) was different than what I expected it to be. Perhaps I
> have a fundamental misunderstanding of how to initially assign variables
> in C? Thank you all for your help and tips. Here is the working code I
> referenced above (still needs testing, but core dumps don’t happen):
> char fcoutpreamble[40];
> char fcokpreamble[40];
> char blah[40];
> int i;
> double MPS[7];
> assign
> “PV1”,
> “PV2”,
> “PV3”
> Monitor MPS;
> SS Machine
> state Start
> when()
> if( PV1 = TRUE)
> /* set arguments here*/
> i = sprintf(blah, “%s_input\n”,fcoutpreamble);
> assert( i <= sizeof(blah));
> pvAssign (MPS[2],blah);
> i = sprintf(blah, “%s_raw\n”,fcoutpreamble);
> pvAssign (MPS[3],blah);
> i = sprintf(blah, “%s_input\n”,fcokpreamble);
> pvAssign (MPS[4],blah);
> i = sprintf(blah, “%s_raw\n”,fcokpreamble);
> pvAssign (MPS[5],blah);
> i = sprintf(blah, “PV3”);
> pvAssign (MPS[6],blah);
> else
> }state Idle
> Dave
Eric Norum
[email protected]
- Re: Problems with Dynamic Array population Brown, David L.
- Problems with Dynamic Array population Brown, David L.
- Re: Problems with Dynamic Array population Benjamin Franksen
Re: Permissible in C to call CA I/O functions from callback? J. Lewis Muir
<2014>
<2014>
