1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Asyn and stringin records
To: <[email protected]>
Date: Fri, 7 Nov 2014 15:57:31 +0000
I have come across a difference in behaviour with asyn and the EPICS stringin record (asyn 4-22 / base 3.14.12.2 / win64) that occurs when the value received by the driver happens to be larger than the stringin maximum size. A record was changed from "periodic scan" to "I/O Intr" resulting in a crash due to a strcpy() (in monitor() from stringinRecord.c of base) being unable to find a NULL terminator and thus overwriting memory. Looking at devAsynOctet.c  it seems that stringin records that are periodically scanned are always guaranteed to have a NULL terminated value, whereas ones processed via interruptCallbackSi() are NULL terminated only if the data received is less than 40 characters long (I noticed that in base 3.14.12.4 the stringinRecord.c monitor() routine now uses strncpy() and so does not require NULL termination). For my case I've just added NULL termination for "I/O Intr" too, but from looking at the stringin record reference manual page I wasn't sure if the ori!
 ginal I/O Instr stringin behaviour was actually more correct?
Freddie
Scanned by iCritical.
RE: Asyn and stringin records Mark Rivers
Prev: Re: catools (caget/caput/camonitor) and locale settings from the environment Torsten Bögershausen
Next: Re: Permissible in C to call CA I/O functions from callback? J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Permissible in C to call CA I/O functions from callback? Andrew Johnson
Next: RE: Asyn and stringin records Mark Rivers
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
