1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: NaN and analog records
To: [email protected]
Date: Wed, 05 Nov 2014 14:43:04 +0100
On 04.11.2014 14:37, [email protected] wrote:
Comparisons between numbers and non-numbers (such as NaN) are
undefined.
Not quite: comparisons involving NaN are defined to always return false.  This means that a test of the form
	if (prec->drvl <= value && value <= prec->drvh)
	    // accept value
	else
	    // reject value
would have the desired effect (and setting a drv limit would cause all values to be rejected!)
Note that the intent of DRVH and DRVL is not to reject values but to truncate the range. So a value larger than DRVH is not ignored but replaced by DRVH. As argued before, NaN is never larger than DRVH, thus the value is accepted.
Dirk
What is your suggestion on how to check limits for a non-number without
using comparisons?
We also found that you can type "NaN" at any entry field in DM2K
which
writes NaN directly to the PV.
NaN, -inf and +inf are valid values for a double. Why would you reject
entering valid values in entry fields?
Cheers,
~Ralph
NaN and analog records Benjamin Franksen
Re: NaN and analog records Goetz Pfeiffer
Re: NaN and analog records Ralph Lange
RE: NaN and analog records michael.abbott
Prev: Re: Record processing during iocInit? Dirk Zimoch
Next: Job opening at PSI (Control System Specialist/Software developer) Celcer Tine
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: NaN and analog records michael.abbott
Next: Re: NaN and analog records Ralph Lange
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
