Hi Keenan,
The issue is most likely to be with your setup.
On 11/04/2014 02:42 PM, Lang, Keenan C. wrote:
> As well, to make sure that my issue isn't with my setup, I have MinGW,
> gnuwin32, and Strawberry Perl installed and my path is set up in the
> following order:
> %REGULAR_PATH%;
> %PATH_TO_MINGW_BIN%;
> %PATH_TO_MSYS_BIN%;
> %PATH_TO_GNUWIN32_BIN%;
> %PATHS_TO_PERL_BINS%
Which version of make.exe do you end up running? We know the GnuWin32
one works and that some others don't and cause weird symptoms like
yours, so you might want to push that directory above the MSYS one.
Since you're using Strawberry Perl, I would recommend using the MinGW
installation that comes with that so you only need to add GnuWin32 to
have a working toolset.
This is my (working) win32-x86-mingw.bat file, which only requires
EPICS_BASE to already be set:
@ECHO OFF
REM ---- Windows
set PATH=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem
REM ---- Strawberry Tools
set PATH=%PATH%;C:\strawberry-32\c\bin
REM ---- Strawberry Perl
set PATH=%PATH%;C:\strawberry-32\perl\site\bin;C:\strawberry-32\perl\bin
REM ---- GnuWin32 Make
set PATH=%PATH%;D:\Applications\GnuWin32\bin
REM ---- EPICS
set EPICS_HOST_ARCH=win32-x86-mingw
set PATH=%PATH%;%EPICS_BASE%\bin\%EPICS_HOST_ARCH%
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
- RE: MinGW PRODDIR_LDFLAGS Lang, Keenan C.
- MinGW PRODDIR_LDFLAGS Lang, Keenan C.
Re: Compiling SDDS problem Chen Xue
<2014>
<2014>
