1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: NaN and analog records
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 04 Nov 2014 13:41:00 +0100
Hello Götz,
On 04/11/2014 13:32, Goetz Pfeiffer wrote:
another problem is that DRVL and DRVH seem to be ignored for NaN.
The following record;
record(ao,"UE56ID3R:BaseParGapTrs") {
     field(ASG,"USERCTL")
     field(DRVH,"0.1")
     field(DRVL,"0")
     field(LINR,"NO CONVERSION")
     field(OIF,"Full")
     field(PREC,"4")
for example can be set to NaN (at least for Epics Base 3.14.8).
Comparisons between numbers and non-numbers (such as NaN) are undefined.
What is your suggestion on how to check limits for a non-number without using comparisons?
We also found that you can type "NaN" at any entry field in DM2K which
writes NaN directly to the PV.
NaN, -inf and +inf are valid values for a double. Why would you reject entering valid values in entry fields?
Cheers,
~Ralph
Re: NaN and analog records Goetz Pfeiffer
Re: NaN and analog records Benjamin Franksen
RE: NaN and analog records michael.abbott
Prev: Re: NaN and analog records Goetz Pfeiffer
Next: Re: compiling issues during building cothread Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: NaN and analog records Goetz Pfeiffer
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
