1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: compiling issues during building cothread
To: <[email protected]>, <[email protected]>
Date: Mon, 3 Nov 2014 12:34:27 +0000
Hi Han,
>    I'm trying to build the cothread-2-12 (gz and git) in my laptop,
> I've got the following error:
> @:~/cothread-2-12$ python setup.py build
> running build
> running build_py
> creating build
> creating build/lib.linux-x86_64-2.7
> creating build/lib.linux-x86_64-2.7/cothread
> copying cothread/catools.py -> build/lib.linux-x86_64-2.7/cothread
> copying cothread/poll_win32.py -> build/lib.linux-x86_64-2.7/cothread
> copying cothread/cothread.py -> build/lib.linux-x86_64-2.7/cothread
> copying cothread/load_ca.py -> build/lib.linux-x86_64-2.7/cothread
> copying cothread/cadef.py -> build/lib.linux-x86_64-2.7/cothread
> copying cothread/coserver.py -> build/lib.linux-x86_64-2.7/cothread
> copying cothread/input_hook.py -> build/lib.linux-x86_64-2.7/cothread
> copying cothread/cosocket.py -> build/lib.linux-x86_64-2.7/cothread
> copying cothread/pv.py -> build/lib.linux-x86_64-2.7/cothread
> copying cothread/__init__.py -> build/lib.linux-x86_64-2.7/cothread
> copying cothread/dbr.py -> build/lib.linux-x86_64-2.7/cothread
> copying cothread/coselect.py -> build/lib.linux-x86_64-2.7/cothread
> creating build/lib.linux-x86_64-2.7/cothread/tools
> copying cothread/tools/pvtree.py -> build/lib.linux-x86_64-
> 2.7/cothread/tools
> copying cothread/tools/__init__.py -> build/lib.linux-x86_64-
> 2.7/cothread/tools
> running build_ext
> building 'cothread._coroutine' extension
> creating build/temp.linux-x86_64-2.7
> creating build/temp.linux-x86_64-2.7/context
> gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall
> -Wstrict-prototypes -fPIC -I/usr/include/python2.7 -c
> context/_coroutine.c -o
> build/temp.linux-x86_64-2.7/context/_coroutine.o -Werror -Wall -Wextra
> -Wno-unused-parameter -Wno-missing-field-initializers -Wundef -Wshadow
> -Wcast-align -Wwrite-strings -Wredundant-decls -Wmissing-prototypes
> -Wmissing-declarations -Wstrict-prototypes
> -Wstrict-prototypes -fPIC -I/usr/include/python2.7 -c context/cocore.c
> -o build/temp.linux-x86_64-2.7/context/cocore.o -Werror -Wall -Wextra
> context/cocore.c: In function ‘delete_stack’:
> context/cocore.c:326:5: error: variable ‘_qzz_res’ set but not used
> [-Werror=unused-but-set-variable]
> cc1: all warnings being treated as errors
> error: command 'gcc' failed with exit status 1
>    Add the  the extra compile arguments in setup.py with
> -Wno-unused-but-set-variable, then the building cothread process can
> be done.
>   I am not sure this is the right approach, because of -Werror arg in
> setup.py. So please tell me it might be ok or not in order to use the
> cothread in my machine. I am using the Debian stable with the most
> up-to-date one and gcc is gcc (Debian 4.7.2-5) 4.7.2
Thank you for the report.
The workaround you have is just fine, and in fact you could instead get away with removing the -Werror from the list in setup.py.  I've always tried to eliminate as many warnings as possible from my code, but maybe I should somehow remove the -Werror from the released version.
What's going on here is rather interesting: a while ago I added valgrind support to cothread, and this uses some rather evil looking code to generate special instructions that only valgrind takes any notice of.  Unfortuately it looks as if your compiler, which is more recent than mine, doesn't like one of the valgrind tricks.
I don't know of a cleaner way to suppress this warning than the workaround you've found.  Do let me know how you get on with cothread!
Re: compiling issues during building cothread Benjamin Franksen
compiling issues during building cothread Jeong Han Lee
Prev: compiling issues during building cothread Jeong Han Lee
Next: Re: Problems with Dynamic Array population Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: compiling issues during building cothread Benjamin Franksen
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
