1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: galil softIOC lose the galil controller
To: Mark Clift <[email protected]>, <[email protected]>
Date: Mon, 3 Nov 2014 15:51:51 +0800
Hi Mark,
    Thanks for your suggestion!
    I checked the linux with “route –n” command,  and the IP address of the galil was in it.
    I changed the unmanaged switch with a managed switch, and the galil softIOC ran a long time without any errors.
Qingru Mi
Sent: Thursday, October 30, 2014 8:17 AM
Subject: galil softIOC lose the galil controller
Hi Qingru,
I would guess that the multi-cast route is missing, which is required for the Galil driver you're using.
We add the following line into /etc/rc.local
route add -net 224.0.0.0 netmask 240.0.0.0 dev eth0
The error simply says it could not poll the first 8 digital inputs with Galil TI (Tell input) command.
Also there is a newer Galil driver designed to replace the one your using located here:
http://motorapp.github.io/Galil-3-0/
Best wishes,
Dr. Mark Clift
Senior Controls Engineer
Australian Synchrotron
800 Blackburn Road
Clayton 3168
Ph: +613 8540 4264
Fax: +613 8540 4200
RE: galil softIOC lose the galil controller Mark Clift
Prev: RE: galil softIOC lose the galil controller Mark Clift
Next: compiling issues during building cothread Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: galil softIOC lose the galil controller Mark Clift
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
