1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Problems with Dynamic Array population
Date: Sun, 2 Nov 2014 16:43:52 +0000
Hi, all,
I am attempting to dynamically populate arrays in a Sequencer using EPICS version R3.14.11.  In order to get around a 40 char limit on PVs, I'm using a database to serve alias PVs with shorter names.  All of the PVs in this one array (defined as a double [7] ) are bi records with bi record inputs.  When I get to the array element #4, the console reads:
"seq_pvMonitor: pvVarMonitorOn() PV_Name
     failure: The data type specified is invalid
 Segmentation fault (core dumped)"
Any ideas as to why this might happen with this one bi record (I'm suspecting that the next one in line does it as well) and not with the other 4 before it?
My code looks sort of like this:
Program Thing
#define something
char var[32];
char var1[32];
char var2[32];
char var3[32];
char var4[32];
char sysid[32];
char sysidn[40];
char preamble1[40];
char preamble2[40];
char preamble3[40];
char blah[40];
string n;
double Array [7];
assign Array "";
monitor Array;
ss State_Machine
State Start
entry
strcpy(var,macValueGet("S"));
strcpy(var1,macValueGet("SS"));
strcpy(var,macValueGet("N"));
strcpy(var,macValueGet("I"));
strcpy(preamble1,var);
strcat(preamble1,var1);
strcat(preamble1,":WS");
strcat(preamble1,"n");
strcat(preamble1,":");
strcat(preamble1,var4);
strcpy(preamble2,var);
strcat(preamble2,var1);
strcat(preamble2,":FC");
strcat(preamble2,"n");
strcat(preamble2,"_out:");
strcat(preamble2,var4);
strcpy(preamble3,var);
strcat(preamble3,var1);
strcat(preamble3,":FC");
strcat(preamble3,"n");
strcat(preamble3,"_ok:");
strcat(preamble3,var4);
when()
if( strcmp(var, "DTL_")==0)
sprintf(blah, "%s_input\n", preamble1);
pvAssign(Array[0],blah);
sprintf(blah, "%s_raw\n", preamble1);
pvAssign(Array[1],blah);
sprintf(blah, "%s_input\n", preamble2);
pvAssign(Array[2],blah);
sprintf(blah, "%s_raw\n", preamble2);
pvAssign(Array[3],blah);
sprintf(blah, "%s_input\n", preamble3);
pvAssign(Array[4],blah);
sprintf(blah, "%s_raw\n", preamble3);
pvAssign(Array[5],blah);
sprintf(blah, "HardCodedPV\n");
pvAssign(Array[6],blah);
} state Next
David Brown
Re: Problems with Dynamic Array population Johnson, Andrew N.
Prev: Re: galil softIOC lose the galil controller Heinz Junkes
Next: Re: Problems with Dynamic Array population Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: devAsynFloat64::initCommon findInterface asynFloat64Type Pearson, Matthew R.
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
