I suspect that in the constructor for your driver you did not set the asynFloat64Mask bit in the interfaceMask argument to the asynPortDriver constructor. If your driver will do callbacks on the asynFloat64 interface you also need to set
that bit in the interruptMask argument to the asynPortDriver constructor.
Hi all,
I’m developing a device that needs to read out a floating point value that forms part of a 24-byte structure read from the serial port.
I’m doing this as an AsynPortDriver device.
I get the above error on my record definition, but I’m not sure why.
I’m still new as an EPICS user, so my question is: can you give me some advice as to what I’m missing?
Many thanks,
Peter.
- RE: devAsynFloat64::initCommon findInterface asynFloat64Type Heesterman, Peter J
- devAsynFloat64::initCommon findInterface asynFloat64Type Heesterman, Peter J
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
