This would still disable all records individually, not the IOC
database processing as a whole.
It also blocks "regular" usage of DISL fields of all your records,
which might not be acceptable in your application.
If you want to completely pause your IOC (including Channel Access
server and client), the function or iocShell command
iocPause
might be what you are looking for.
Calling
iocRun
later on should bring a paused IOC back to life.
Note that these calls are not widely and frequently used, so there
might still be side effects that we are not aware of. (But would
definitely want to know about!)
Good luck,
~Ralph
On 30/10/2014 18:24, Dalesio, Leo
wrote:
Put the DISL of every PV to point to
one PV - and put a button on just that one. I think that there
is mention of this in the Record Reference Manual and/or the
Application Developer's Guide.
Bob
Hi All,
This may sound like an odd request, but is there a
way to stop processing all PVs in the database? I
know I can stop processing individual PVs using the
DISV field, but I was wondering if there was a way
to stop processing the whole database at once
without looping through every PV.
Thanks in advance for any suggestions.
Elmer Pensack
- Disable database question Elmer Pensack
- RE: Disable database question Dalesio, Leo
Re: Disable database question Andrew Johnson
RE: Disable database question Zelazny, Michael Stanley
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
