1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: areaDetector 2.0 on windows xp 32bit
To: [email protected]
Date: Thu, 30 Oct 2014 10:36:59 +0100
Dear all,
I have installed the prebuild binaries of areaDetector (ADroper driver)
for windows 32bit.
I installed medm from the EPICS windows tools (medm.exe is on the windows
PATH) and the cygwin/X windows server.
I run xterm from the cygwin XLauncher (local) and move to the folder with
start_epics.bat file.
When running this file I have two problems
1) MEDM is no staring. I have and error windows with the message that
medm.exe is not a valid win32 application.
2) The ioc starts but with lots of error messages that I don't understand
(output of termimal below)
Can anyone point to me where can be the errors?
Thanks in advance for the help
C:\base-3.14.12.4\support\areaDetector-2-0\ADRoper\iocs\roperIOC\iocBoot\iocRoper1>..\..\bin\win32-x86\roperApp
st.cmd
macLib: macro ADCORE is undefined (expanding string
dbLoadRecords("$(ADCORE)/db/ADBase.template",
"P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1"))
dbLoadRecords("$(ADCORE)/db/NDFile.template",
macLib: macro ADROPER is undefined (expanding string
dbLoadRecords("$(ADROPER)/db/roper.template",
dbLoadRecords("$(ADCORE)/db/NDPluginBase.template","P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),NDARRAY_ADDR=0"))
dbLoadRecords("$(ADCORE)/db/NDStdArrays.template",
"P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,TYPE=Int16,FTVL=SHORT,NELEMENTS=1500000"))
macLib: macro ADCORE is undefined (expanding string <
$(ADCORE)/iocBoot/commonPlugins.cmd)
set_requestfile_path("$(ADROPER)/roperApp/Db"))
Starting iocInit
save_restore:readReqFile: unable to open file ADBase_settings.req. Exiting.
save_restore:readReqFile: unable to open file NDFile_settings.req. Exiting.
save_restore:readReqFile: unable to open file roper_settings.req. Exiting.
save_restore:readReqFile: unable to open file NDPluginBase_settings.req.
Exiting.
save_restore:readReqFile: unable to open file NDStdArrays_settings.req.
Exiting.
save_restore:readReqFile: unable to open file commonPlugin_settings.req.
Exiting.
auto_settings.sav: 0 of 0 PV's connected
< envPaths
epicsEnvSet("ARCH","win32-x86")
epicsEnvSet("IOC","iocPVCam1")
epicsEnvSet("TOP","C:/base-3.14.12.4/support/areaDetector-2-0/ADRoper/iocs/roperIOC")
epicsEnvSet("SUPPORT","","C:/base-3.14.12.4/support")
epicsEnvSet("ASYN","C:/base-3.14.12.4/support/asyn-4-22")
epicsEnvSet("CALC","C:/base-3.14.12.4/support/calc-3-2")
epicsEnvSet("BUSY","C:/base-3.14.12.4/support/synApps_5_7/support/busy-1-6")
epicsEnvSet("SSCAN","C:/base-3.14.12.4/support/sscan-2-9")
epicsEnvSet("AUTOSAVE","C:/base-3.14.12.4/support/synApps_5_7/support/autosave-5-1")
epicsEnvSet("AREA_DETECTOR","C:/base-3.14.12.4/support/areaDetector-2-0")
epicsEnvSet("EPICS_BASE","C:/base-3.14.12.4")
errlogInit(20000)
dbLoadDatabase("C:/base-3.14.12.4/support/areaDetector-2-0/ADRoper/iocs/roperIOC/dbd/roperApp.dbd")
roperApp_registerRecordDeviceDriver(pdbbase)
Warning: IOC is booting with TOP =
          but was built with TOP =
"J:/epics/devel-AD2.0/areaDetector/ADRoper/iocs/roperIOC"
epicsEnvSet("PREFIX", "13ROPER1:")
epicsEnvSet("PORT",   "ROPER1")
epicsEnvSet("QSIZE",  "20")
epicsEnvSet("XSIZE",  "1396")
epicsEnvSet("YSIZE",  "1040")
epicsEnvSet("NCHANS", "2048")
roperConfig("ROPER1", 0, 0)
asynSetTraceIOMask("ROPER1",0,2)
#asynSetTraceMask("$(PORT)",0,9)
# Create a standard arrays plugin, set it to get data from the Roper driver.
NDStdArraysConfigure("Image1", 5, 0, "ROPER1", 0, 0)
# Load all other plugins using commonPlugins.cmd
iocInit()
## EPICS R3.14.12.3 $Date: Mon 2012-12-17 14:11:47 -0600$
## EPICS Base built Sep 18 2013
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30,"P=13ROPER1:")
epics> save_restore:write_save_file: Backup file (auto_settings.savB) bad
or not found.  Writing a new one. [141030-103703]
RE: areaDetector 2.0 on windows xp 32bit Mark Rivers
Prev: RE: galil softIOC lose the galil controller Mark Clift
Next: RE: areaDetector 2.0 on windows xp 32bit Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: DG 645 burst mode Prerana Kankiya
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
