Hi Heinz,
Please follow this setup procedure for the RIO PLC.
1. Use GalilTools to set the IP address
2. Record the MAC address of the RIO
3. Edit /etc/rc.d/rc.local and add the following:
# Add multicast route for Galil hardware
route add -net 224.0.0.0 netmask 240.0.0.0 dev eth0
# Add arp entry for Galil RIO device
arp -s <IPADDRESS> <MACADDRESS>
4. Reboot softIOC or type above commands as root, then exit root login
5. Telnet into RIO from softIOC, and issue the following commands
:IB1 (Possibly IK1 on some firmware)
:BN (Burn the changes)
:^M
exit
6. From now on only hosts with the arp entry can telnet into RIO
Then try the IOC again. I recommend using a single IOC and connection to the RIO.
Also try the email again.
Best wishes,
Mark.
Dr. Mark Clift
Senior Controls Engineer
Australian Synchrotron
800 Blackburn Road
Clayton 3168
Ph: +613 8540 4264
Fax: +613 8540 4200
Mail: [email protected]
Sent: Thursday, 30 October 2014 19:16
To: Mark Clift
Cc: [email protected] ([email protected])
Subject: Re: galil softIOC lose the galil controller
Hi techtalk,
we are running two galil RIO-47120 controllers. We are using the newest versions of galilsuite and galiltools on debian linux.
ii galilsuite 1.0.2 amd64 Test GalilSuite build
ii galiltools 1.6.3 amd64 GalilTools
and the Galil-3-0 motorapp.
We could'nt get them running stable. Until the day before yesterday I connected to both controllers with one softioc. About every second week they stopped working and the controllers could'nt be ping-ed anymore. We have to reset the controllers. Both stopped at the same time.
Now I run two softioc's on the same Unix-System. Each of them opens a connection to a single controller ... now they sopped working after about 5-6 hours.
And again both of them at the same time. I have no info's in any log-file.
The program on the IOC is very simple:
dmc-file, rioDIag.dmc :
'Galil Motion Control [email protected]
'http://www.galilmc.com/
#epics
'Insert code to run on
' GalilStartController() here...
MA 141,14,141,214;
MD [email protected];
MS [email protected];
WT 100
XQ#update,1;'spawn update thread
EN
#update;'Example update loop
AT0
epics[0]=TIME;'time tick
epics[1]=_OP0
epics[2]=_TI0
OPepics[9]
IF (epics[10])
SB8
WT50
CB8
epics[10]=0
ENDIF
AT200;'see SCAN field in
' galil_array_access.substitutions
JP#update
#CMDERR;'runs if an error occurs
MG "An error occured at line",_ED
TC 1;'print type of error info
ZS;'Remove returns from callbck
EN;'End execution
#TCPERR
MG {M} "TCPERR. Dropped handle", _IA4
RE
started with this cmd-file, rioDiag.cmd:
#Galil Motion Control [email protected] http://www.galilmc.com/
#Load Galil Data Record Support
#dbLoadTemplate("$(TOP)/GalilDiagApp/Db/rioDiag_motor.substitutions")
#Provide access to Galil Array Table
dbLoadTemplate("$(TOP)/GalilDiagApp/Db/rioDiag_array_access.substitutions")
# GalilCreateController command parameters are:
# 1. Const char *portName - The name of the asyn port to be created for this controller
# 2. Const char *address - The address of the controller
# 3. int numAxes - The number of axis that will be used on the controller
# 4. double updatePeriod - The time in ms between datarecords
# (See controller's DR command for minimum).
# Async if controller + bus supports it, otherwise is polled/synchronous.
GalilCreateController("rioDiag", "10.0.0.210", 1, 32)
#GalilCreateController("rioDiag", "141.14.128.41", 2, 8)
# GalilCreateAxis command parameters are:
# 1. char *portName Asyn port for controller
# 2. char axis A-H,
GalilCreateAxis("rioDiag","A")
#GalilCreateAxis("rioDiag","B")
#GalilCreateAxis("Galil","C")
#GalilCreateAxis("Galil","D")
#GalilCreateAxis("Galil","E")
#GalilCreateAxis("Galil","F")
#GalilCreateAxis("Galil","G")
#GalilCreateAxis("Galil","H")
# GalilStartController command parameters are:
# 2. char *code file to deliver to the controller, "" for none.
# 3. char *label to execute on file, "" to not execute.
GalilStartController("rioDiag", "rioDiag.dmc", "#epics")
and this st.cmd:
#!../../bin/linux-x86_64/GalilDiagApp
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","IOCRIODIAG")
epicsEnvSet("TOP","/srv/ioc/sys/$(IOC)")
#epicsEnvSet("SUPPORT","/home/epics/EPICS/support")
#epicsEnvSet("EPICS_BASE","/home/epics/EPICS/base")
#epicsEnvSet("ASYN","/home/epics/EPICS/support/asyn/asyn4-22")
#epicsEnvSet("MOTOR","/home/epics/EPICS/support/motor/motorR6-8")
epicsEnvSet("DISPLAY",":0")
epicsEnvSet("LOG_DIR", "/srv/ioc/log")
dbLoadDatabase("$(TOP)/dbd/GalilDiagApp.dbd",0,0)
GalilDiagApp_registerRecordDeviceDriver(pdbbase)
# Configure an example controller
#< rioMezz.cmd
< rioDiag.cmd
#dbLoadRecords ("$(TOP)/db/rioMezz.db","P=FHIFEL:,R=HELPER:,S=GUNRELAY:")
dbLoadRecords("$(TOP)/db/attenuator.db","P=FHIFEL:,R=DIAG:,S=ATTENUATOR:")
dbLoadRecords("$(TOP)/db/flipper.db","P=FHIFEL:,R=DIAG:,S=FLIP:")
#dbLoadRecords("$(TOP)/db/checkAlive.db","RIO=rioMezz:")
dbLoadRecords("$(TOP)/db/checkAlive.db","RIO=rioDiag:")
## autoSaveRestore setup
save_restoreSet_Debug(0)
# status-PV prefix, so save_restore can find its status PV's.
save_restoreSet_status_prefix("${IOC}:")
# ok to restore a save set that had missing values (no CA connection to PV)?
# ok to save a file if some CA connections are bad?
save_restoreSet_IncompleteSetsOk(1)
#In the restore operation, a copy of the save file will be written. The
# file name can look like "auto_settings.sav.bu", and be overwritten every
# reboot, or it can look like "auto_settings.sav_020306-083522" (this is what
# is meant by a dated backup file) and every reboot will write a new copy.
save_restoreSet_DatedBackupFiles(1)
# specify where save files should go
set_savefile_path("/srv/ioc/log/as","/save")
# specify where request files can be found
set_requestfile_path("/srv/ioc/log/as","/req")
# Specify what save files should be restored when.
# Up to eight files can be specified for each pass.
set_pass0_restoreFile("${IOC}_0.sav")
set_pass1_restoreFile("${IOC}_1.sav")
# Number of sequenced backup files (e.g., 'auto_settings.sav0') to write
save_restoreSet_NumSeqFiles(3)
save_restoreSet_SeqPeriodInSeconds(600)
# Time between failed .sav-file write and the retry.
save_restoreSet_RetrySeconds(60)
iocInit()
makeAutosaveFileFromDbInfo("/srv/ioc/log/as/req/${IOC}_0.req", "autosaveFields_pass0")
makeAutosaveFileFromDbInfo("/srv/ioc/log/as/req/${IOC}_1.req", "autosaveFields_pass1")
create_monitor_set("${IOC}_0.req", 5, "P=${IOC}:")
create_monitor_set("${IOC}_1.req", 30, "P=${IOC}:")
## Report Installed and Configured I/O-Hardware Information
dbior 0 1 > ${LOG_DIR}/Database/${IOC}.dbior
dbhcr > ${LOG_DIR}/Database/${IOC}.dbhcr
dbl > ${LOG_DIR}/Database/${IOC}.dbl
By the way, the mail-sending on RIO works only once or twice .. then it stops sending any mails
Best regards,
Heinz
On 30.10.2014, at 01:17, Mark Clift <[email protected]> wrote:
> Hi Qingru,
> I would guess that the multi-cast route is missing, which is required for the Galil driver you're using.
> We add the following line into /etc/rc.local
> The error simply says it could not poll the first 8 digital inputs with Galil TI (Tell input) command.
> Also there is a newer Galil driver designed to replace the one your using located here:
> http://motorapp.github.io/Galil-3-0/
> Best wishes,
> Mark
> Dr. Mark Clift
> 800 Blackburn Road
> Clayton 3168
> Ph: +613 8540 4264
> Fax: +613 8540 4200
- Re: galil softIOC lose the galil controller Heinz Junkes
- Re: galil softIOC lose the galil controller Pearson, Matthew R.
- galil softIOC lose the galil controller Mark Clift
areaDetector 2.0 on windows xp 32bit Zunbeltz Izaola
<2014>
<2014>
