1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Focus deadlock
Date: Fri, 24 Oct 2014 19:19:21 +0000
Mark, Pete,
I do not need to run the IOC to get a problem: just MEDM is enough.
If I start MEDM, start Winteracter, stop MEDM, the focus deadlock continues.
If I run medm pilatusDetector.adl without “-x” (is this edit mode?) I still get a focus deadlock.
Tried running a few other MEDM applications and generally saw the same problem.
Eliot Specht
To:          <[email protected]>
Date:     Fri, 24 Oct 2014 12:29:37 -0500
That's the real test.  ... stop MEDM and see if problem continues.
Another test is, with MEDM and Winteracter application both running, stop the IOC and see if the focus stops switching.
Seems that an experienced Motif programmer might understand how this interaction is even possible.
You asked:
> What kind of events are created by the EPICS system which
> could be picked up by an application which is not EPICS-aware?
MEDM receives CA monitor updates and converts some of those updates into updates to its Motif interface. These updates in MEDM are the path, however remote such a possibility exists, that Motif events from MEDM are being received by your Winteracter application.
On 10/24/2014 11:46 AM, Mark Rivers wrote:
Hi Eliot,
If you stop medm from processing events by putting it in edit mode does the problem immediately stop?
If you kill medm and run another EPICS Motif CA application (probe, stripTool, etc.) do you have the problem?
From: [email protected] [[email protected]] on behalf of Jennings, Guy [[email protected]]
Sent: Friday, October 24, 2014 11:10 AM
To: [email protected]
Doesn’t the common factor seem to be motif?
On Oct 24, 2014, at 9:50 AM, Specht, Eliot D. <[email protected]> wrote:
Pete,
Can you help me to make a well-posed question for the Winteracter developer? What kind of events are created by the EPICS system which could be picked up by an application which is not EPICS-aware? That is, how would you describe a CA monitor event to a developer who is unfamiliar with EPICS?
Eliot Specht
Date:     Fri, 24 Oct 2014 07:50:49 -0500
Can this be a an issue where the GUI is receiving CA monitor events directly and focusing the associated window with each event? If so, can you throttle widget updates in Winteracter to a fixed interval rather than updating the GUI for each CA monitor event received?
On 10/24/2014 7:36 AM, Specht, Eliot D. wrote:
I’m seeing a conflict between:
“medm pilatusDetector.adl” and a Winteracter program.  Winteracter
creates GUIs for Fortran programs using Motif. The Winteracter program
is simply waiting for input while the problem occurs. The result is that
input focus shifts rapidly between two Winteracter windows. The medm
windows do not get input focus, so it’s hard to understand how medm
contributes to the problem.
Date:     Thu, 23 Oct 2014 13:26:17 -0500
What are the GUI applications involved?
On 10/23/2014 1:15 PM, Specht, Eliot D. wrote:
I’m running an application on a Linux x86_64 machine which opens several
windows for user input and data display. It runs fine unless I have an
EPICS areadetector IOC running in the background, in which case I get a
“focus deadlock”, where focus shifts rapidly between two application
windows and the screen becomes unresponsive to keyboard or mouse input.
The problem occurs under Gnome but not KDE. Running KDE is an effective
fix, but it would be nice to get to the bottom of the problem. Can
anyone suggest what’s going on?
Eliot Specht                        Voice: (865)574-7682
Oak Ridge National Laboratory       FAX:   (865)574-4913
P.O. Box 2008, MS 6064
Oak Ridge, TN 37831-6064
Pete R. Jemian, Ph.D.                <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source,   Argonne National Laboratory
Argonne, IL  60439                   630 - 252 - 3189
    Education is the one thing for which people
       are willing to pay yet not receive.
Re: Focus deadlock Pete Jemian
Prev: Re: Focus deadlock Pete Jemian
Next: Re: Focus deadlock Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
