1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: order of rules in Makefile
To: EPICS Tech Talk <[email protected]>
Date: Thu, 23 Oct 2014 18:28:34 +0000
Hi Andrew,
> Why do you have to run the conversion tool from the top level
> Makefile? I would personally try to avoid mixing up rules from
> different build areas, so would either add a new directory to run
> the tool in, run it in the directory it was built in, or in the docs
> directory.
Thanks, I fixed this issue as you said: I moved the raw data to a
different folder, do the conversion there and install all data files
(pre-conversion and converted) into $(TOP)/data. Then I can build the
documentation using these files.
Thanks for your input,
Martin
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
order of rules in Makefile Konrad, Martin
Prev: Re: Focus deadlock Pete Jemian
Next: RE: Focus deadlock Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: order of rules in Makefile Johnson, Andrew N.
Next: PV monitoring and email reporting tool Alex Wallace
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
