1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Discussion about licenses, copyrights, business, and source code
To: "J. Lewis Muir" <[email protected]>
Cc: EPICS mailing list <[email protected]>
Date: Thu, 23 Oct 2014 07:58:45 +0000
Hi Lewis,
> On Oct 23, 2014, at 00:07, J. Lewis Muir <[email protected]> wrote:
>> On 10/22/14 4:45 PM, Johnson, Andrew N. wrote:
>> I would be careful with making assumptions about using “plug-in”
>> programs, the GPLv3 definition for Corresponding Source "includes
>> interface definition files associated with source files for the work,
>> and the source code for shared libraries and dynamically linked
>> subprograms that the work is specifically designed to require,
>> such as by intimate data communication or control flow between
>> those subprograms and other parts of the work.” This means that
>> “intimate” inter-program communication could also require your
>> program to be released under the GPL in some cases.
> See:
>  http://www.gnu.org/licenses/gpl-faq.html#GPLAndPlugins
> To me, that supports what I said.
Read the following FAQ points as well, there are subtle distinctions between whether your main application is GPL or your plugin is GPL, and I think the example you pointed to was for a non-GPL plugin to a GPL application.
- Andrew
Sent from my iPad
Re: Discussion about licenses, copyrights, business, and source code J. Lewis Muir
Discussion about licenses, copyrights, business, and source code Emmanuel Mayssat
Re: Discussion about licenses, copyrights, business, and source code Johnson, Andrew N.
Prev: Re: AsynPortDriver setting DRVH of ao? Florian Feldbauer
Next: Re: PV monitoring and email reporting tool Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Discussion about licenses, copyrights, business, and source code J. Lewis Muir
Next: Re: Discussion about licenses, copyrights, business, and source code J. Lewis Muir
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
