1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: PV monitoring and email reporting tool
To: [email protected]
Date: Wed, 22 Oct 2014 10:45:23 -1000
On 10/22/14 09:47, Konrad, Martin wrote:
Hi Alex,
Does anyone know of a good tool that can be used to generate email
reports of EPICS PVs on a regular basis? I am thinking I'd like to have
a daily summary of our vacuum systems in my email, and perhaps someone
has already built a tool for this?
How about a cron job that runs caget? Or do you need a plot with the
last 24 h of history? In this case I would recommend pulling the data
from an archiver.
I have a cron job that put things out once per day (reset daily
minima and maxima), that's relatively easy to put together.
I was also going to suggest an archiver. If you only want to archive
once per day, that's up to you.
HTH,
Maren
Re: PV monitoring and email reporting tool Konrad, Martin
Prev: Re: Trouble building debug version of areaDetector 2.x (from git) John Hammonds
Next: RE: Possible to close a TCP/IP socket in asyn? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: PV monitoring and email reporting tool Konrad, Martin
Next: Possible to close a TCP/IP socket in asyn? Adam Bark
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
