1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Interface Labview and EPICS
To: <[email protected]>
Date: Wed, 22 Oct 2014 13:50:00 +0000
Hi Yuan,
CA Lab by Carsten et. al. is a good option, there are a few others out there, so if it doesn’t fulfil your requirements there may be other options. It does depend on how your LabVIEW is architected.
There’s also lvDCOM (http://epics.isis.stfc.ac.uk/) which has been written here, which doesn’t require any alteration of LabVIEW code to interact with the PVs, although you may have to alter your LabVIEW preferences.
At the moment where we need LabVIEW to ‘serve’ PVs we use lvDCOM, and are starting to use CA Lab when we need to access PVs from LabVIEW.
Kathryn
Sent: 22 October 2014 14:20
To: [email protected]
Subject: Re: Interface Labview and EPICS
Hello Yuan,
we developed a nice interface called CA Lab. All you need  you can find here: http://www-csr.bessy.de/control/SoftDist/CA_Lab/
Carsten Winkler
Scanned by iCritical.
Interface Labview and EPICS Gao, Yuan
Re: Interface Labview and EPICS Carsten Winkler
Prev: Re: Interface Labview and EPICS Carsten Winkler
Next: asyndriver : Multiple drvAsynIPPort Patel Jignesh
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Interface Labview and EPICS Olivier Zimmermann
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
