1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem with CSS archive engine
To: 龙巍 <[email protected]>
Date: Tue, 21 Oct 2014 09:37:47 +0000
By default a VxWorks IOC tries to synchronize its OS clock with an NTP server running on its boot host, but if you have NTP available from a different IP address you can configure that by setting the environment variable EPICS_TS_NTP_INET. You may also need to set the EPICS_TIMEZONE variable to your local timezone, see the comments in the base/configure/CONFIG_SITE_ENV file for details of the format of that variable.
- Andrew
Sent from my iPad
> On Oct 21, 2014, at 10:50, 龙巍 <[email protected]> wrote:
> hello Ralph,
> Thanks for your suggestions,I got the date from the IOC shell:
> ->date
> 1990/01/02 00:45:24.212000
> Just like you said, the IOC was not able to synchronize its time. But I
> don't know how to do.
> Can you give me some advice?
> And, there is a warning when the IOC start:
> ## EPICS R3.14.12.1 $Date: Tue 2011-04-26 15:36:19 -0500$
> ## EPICS Base built May 30 2014
> WARNING: OS Clock time was read before being set.
> Using 1990-01-02 00:00:00.000000 UTC
> iocRun: All initialization complete
> Our IOC runs on the VxWorks OS system.
> So .. is anyone know how to set the OS Clock time?
Re: Problem with CSS archive engine 龙巍
Prev: Re: Problem with CSS archive engine 龙巍
Next: RE: License or copyright for the naming module in DISCS Vuppala, Vasu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Problem with CSS archive engine 龙巍
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
