1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Trouble building debug version of areaDetector 2.x (from git)
To: "'John Hammonds'" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 17 Oct 2014 21:42:56 +0000
Hi John,
I reproduced your problem and fixed it.  The problem was the ADCore/ADApp/commonDriverMakefile was correctly setting this flag:
   USR_LDFLAGS_WIN32     += /NODEFAULTLIB:LIBCMT.lib
but only for 32-bit debug builds on Windows, not for 64-bit builds.
The patch below fixes the problem.  It only assumes that the architecture that you are building (e.g. windows-x64-debug) contains the string "debug" in it.  So it will work with windows-x64-dynamic-debug or win32-x86-debug-static, etc.  There may be a more robust way to check whether it is a debug build or not.
corvette:areaDetector/ADCore/ADApp>git diff
diff --git a/ADApp/commonDriverMakefile b/ADApp/commonDriverMakefile
index 41edaf0..27bee4c 100644
--- a/ADApp/commonDriverMakefile
+++ b/ADApp/commonDriverMakefile
@@ -36,8 +36,11 @@ else
   endif
   PROD_LIBS_WIN32       += tiff jpeg
 endif
-ifeq (win32-x86-debug, $(findstring win32-x86-debug, $(T_A)))
+ifeq ($(OS_CLASS), WIN32)
+  ifeq (debug, $(findstring debug, $(T_A)))
+  endif
 endif
 ifeq ($(STATIC_BUILD), NO)
diff --git a/ADApp/commonLibraryMakefile b/ADApp/commonLibraryMakefile
index 73dcadc..3a0154f 100644
--- a/ADApp/commonLibraryMakefile
+++ b/ADApp/commonLibraryMakefile
@@ -32,8 +32,10 @@ else
   LIB_LIBS_WIN32        += tiff jpeg
 endif
+  endif
 endif
Please let me know if this fixes the problem for you as well, and I will either make a new release or put a link to the patch in the release notes.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of John Hammonds
Sent: Friday, October 17, 2014 3:34 PM
To: [email protected]
Subject: Trouble building debug version of areaDetector 2.x (from git)
I am trying to build a debug version of areaDetector 2.  I have tried
this both building with EPICS_HOST_ARCH=windows-x64 and a cross compile
for windows-x64-debug and also directly building with
EPICS_HOST_ARCH=windows-x64-debug.  The output for the make is in the
included file.  I am use base 3.14.12.4 with synApps_5_7 (w/ asyn-4-23,
autosave-5-4 ).  I am using visual studio 2013, Windows 7-64.
It looks like it is trying to include debug and non debug versions of
libcmt.  Any idea what is wrong here?
John
John Hammonds
Software Services Group
Advanced Photon Source
Argonne National Laboratory
[email protected]
Re: Trouble building debug version of areaDetector 2.x (from git) John Hammonds
Prev: Re: Trouble building debug version of areaDetector 2.x (from git) Christian Roehrig
Next: Problem with CSS archive engine 龙巍
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Trouble building debug version of areaDetector 2.x (from git) John Hammonds
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
