Subject: |
Re: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree |
Heinz Junkes <[email protected]> |
To: |
"J. Lewis Muir" <[email protected]> |
Cc: |
EPICS tech-talk <[email protected]> |
Date: |
Thu, 16 Oct 2014 07:57:06 +0200 |
Hi Lewis,
I build it from source.
Setting the env-vars like this:
h1:iocSimDetector junkes$ export DYLD_LIBRARY_PATH=/opt/local
h1:iocSimDetector junkes$ export LD_LIBRARY_PATH=/opt/local
leads to the same error:
h1:iocSimDetector junkes$ ../../bin/darwin-x86/simDetectorApp st.cmd.darwin
Referenced from: /Users/junkes/PARIS_14/EPICS/support/areaDetector/ADCore/lib/darwin-x86/libNDPlugin.3.14.12.dylib
Expected in: flat namespace
in /Users/junkes/PARIS_14/EPICS/support/areaDetector/ADCore/lib/darwin-x86/libNDPlugin.3.14.12.dylib
Trace/BPT trap: 5
Heinz
On 15 Oct 2014, at 22:59, J. Lewis Muir <[email protected]> wrote:
> On 10/15/14 3:44 PM, Heinz Junkes wrote:
>> _xmlFree can be found in /opt/local/libxml2.dylib
>> 00000000000f2b28 D _xmlFree
>> Pointing LD_LIBRARY_PATH and DYLD_LIBRARY_PATH to this dir will not
>> solve the problem:
>> LD_LIBRARY_PATH=/opt/local/lib
>> DYLD_LIBRARY_PATH=/opt/local/lib
>> Any idea?
> Hi, Heinz.
> Did you build from source, or are you using the pre-built binary
> version? If you're using the pre-built binary, then there is likely
> something wrong with it since it should include any libraries it needs.
> Moving beyond that, you said the symbol _xmlFree can be found in
> /opt/local/libxml2.dylib, but then you set LD_LIBRARY_PATH and
> DYLD_LIBRARY_PATH to /opt/local/lib. Note that the path ends in a
> directory named "lib". If the libxml2.dylib library is in /opt/local,
> then you'd need to set LD_LIBRARY_PATH and DYLD_LIBRARY_PATH to
> /opt/local, not /opt/local/lib.
> Lewis
smime.p7s
Description: S/MIME cryptographic signature
- areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree Heinz Junkes
- Re: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree J. Lewis Muir
Re: Support for hivolt power supply Jörn Wüstenfeld
Re: AsynPortDriver setting DRVH of ao? Florian Feldbauer
<2014>
Re: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree [Solved] Heinz Junkes
<2014>
