Subject: |
Re: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree |
"J. Lewis Muir" <[email protected]> |
To: |
Heinz Junkes <[email protected]>, EPICS tech-talk <[email protected]> |
Date: |
Wed, 15 Oct 2014 15:59:33 -0500 |
On 10/15/14 3:44 PM, Heinz Junkes wrote:
> _xmlFree can be found in /opt/local/libxml2.dylib
> 00000000000f2b28 D _xmlFree
> Pointing LD_LIBRARY_PATH and DYLD_LIBRARY_PATH to this dir will not
> solve the problem:
> LD_LIBRARY_PATH=/opt/local/lib
> DYLD_LIBRARY_PATH=/opt/local/lib
> Any idea?
Hi, Heinz.
Did you build from source, or are you using the pre-built binary
version? If you're using the pre-built binary, then there is likely
something wrong with it since it should include any libraries it needs.
Moving beyond that, you said the symbol _xmlFree can be found in
/opt/local/libxml2.dylib, but then you set LD_LIBRARY_PATH and
DYLD_LIBRARY_PATH to /opt/local/lib. Note that the path ends in a
directory named "lib". If the libxml2.dylib library is in /opt/local,
then you'd need to set LD_LIBRARY_PATH and DYLD_LIBRARY_PATH to
/opt/local, not /opt/local/lib.
Lewis
- Re: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree Heinz Junkes
- areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree Heinz Junkes
Support for hivolt power supply Emma Shepherd
<2014>
<2014>
