1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree
To: EPICS tech-talk <[email protected]>
Date: Wed, 15 Oct 2014 22:44:16 +0200
Dear all,
I just have installed on my Mac (OS X 10.9.5) the new areadetector according to the instructions:
https://github.com/areaDetector/areaDetector/blob/master/INSTALL_GUIDE.md
Everything worked well. If i try to start the simDetectorIOC I run into this:
h1:iocSimDetector junkes$ ../../bin/darwin-x86/simDetectorApp st.cmd.darwin
  Referenced from: /Users/junkes/PARIS_14/EPICS/support/areaDetector/ADCore/lib/darwin-x86/libNDPlugin.3.14.12.dylib
  Expected in: flat namespace
 in /Users/junkes/PARIS_14/EPICS/support/areaDetector/ADCore/lib/darwin-x86/libNDPlugin.3.14.12.dylib
Trace/BPT trap: 5
_xmlFree can be found in /opt/local/libxml2.dylib
00000000000f2b28 D _xmlFree
Pointing LD_LIBRARY_PATH  and DYLD_LIBRARY_PATH to this dir will not solve the problem:
LD_LIBRARY_PATH=/opt/local/lib
DYLD_LIBRARY_PATH=/opt/local/lib
Any idea?
Heinz
P.S. runs on Ubuntu-Linux perfect, but for the training on Monday in Paris, I did not want to bring a server.
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree J. Lewis Muir
Prev: RE: TCP connection status : drvAsynIPPort Mark Rivers
Next: Re: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: AsynPortDriver setting DRVH of ao? Florian Feldbauer
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
