Hi both,
if whoever is administering the firewall knows what they're doing
they can just let certain ports through. Our sysadmins do that
here.
HTH,
Maren
On 10/09/14 09:28, Mark Rivers wrote:
Hi Nicholas,
If the server in the US is really not blocked by a firewall then you
should be able to do the following on your client machine in Germany:
- Set the environment variable EPICS_CA_ADDR_LIST to include the IP
address of the server in the US
- You may also need to change some timing parameters. Read the section
called Configuration in this document:
http://www.aps.anl.gov/epics/base/R3-14/8-docs/CAref.html
- Run the basic EPICS utilities from EPICS base:
cainfo ‘pvname’
getget ‘pvname’
- Launch your MCA client
As Lewis said this would be a dangerous configuration to have the server
not behind a firewall, since anyone could access it.
[mailto:[email protected]] On Behalf Of Nicolas Strauss
Sent: Thursday, October 09, 2014 9:45 AM
To: [email protected]
Subject: MCA and WAN connection
Dear EPICS support,
I'm trying to access a channel with a PV from a server (located in the
USA and me sitting in Germany) with MCA for Matlab.
For this I'm trying CH1=mcaopen('pvname') but without success.
The question for me is, if the reason for this is the firewall of the
server (but should be cutoff) or if I have to add the specific IP of the
server to any file? (library)
Probably problems in the different subnets?
What/where is the parameter which has to be changed?
Thank you for responding my question!
Nicolas
- MCA and WAN connection Nicolas Strauss
- RE: MCA and WAN connection Mark Rivers
Re: Fanout to Sub Records in a Different IOC Causes Core Dump Konrad, Martin
RE: Epics Qt at APS: Formal presentation + discussion Emmanuel Mayssat
<2014>
PCASpy 0.5.1 Xiaoqiang Wang
<2014>
