1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Driver/Protocol for Lin Engineering Silverpak 23CE stepper motor
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 6 Oct 2014 10:51:52 +0000
Hi Mark
We have a protocol file that – for reasons unknown to any current employee – ties into a sequencer.  There could well be a good reason for the way it was done.  It’s fragile and temperamental but it’s been going OK.  However, we now need things like backlash takeout moves and nobody wants to touch this lest we break something completely. I’m getting enough experience with the motor app/records to know that a driver would be the best way to go long term.
Thanks for pointing me toward those base classes.  The command set for the Silverpak is pretty simple, so it may be relatively trivial to copy and modify the drivers you suggested.
Regards
Peter
Sent: Saturday, 4 October 2014 1:08 AM
To: Peter Linardakis; [email protected]
Hi Peter,
What do you already have?
If you do end up writing a new driver, I would encourage you to consider using the asynMotorController and asynMotorAxis base classes in motor/motorApp/MotorSrc.
There are some examples of simple drivers that use this architecture, for example:
motor/motorApp/ACRSrc/ACRMotorDriver.cpp (507 lines of code)
motor/motorApp/AcsSrc/MCB4BDriver.cpp  (336 lines of code)
From: [email protected] [mailto:[email protected]] On Behalf Of Peter Linardakis
Sent: Friday, October 03, 2014 12:58 AM
To: [email protected]
Subject: Driver/Protocol for Lin Engineering Silverpak 23CE stepper motor
Hello all
Does anyone out there have a driver or a good protocol file for a Lin Engineering Silverpak 23CE integrated stepper motor, driver and controller?  I just thought I’d check before embarking on an unfortunately necessary re-write of what we already have.
Regards
Peter
Dr Peter Linardakis
Accelerator Research & Development Engineer
Nuclear Physics | Research School of Physics and Engineering
Australian National University
e: [email protected]
p: +61 2 6125 2862
w: http://physics.anu.edu.au/nuclear/
Driver/Protocol for Lin Engineering Silverpak 23CE stepper motor Peter Linardakis
RE: Driver/Protocol for Lin Engineering Silverpak 23CE stepper motor Mark Rivers
Prev: Re: [EPICS] Support for Staged Installs ? Michael Davidsaver
Next: PICAM areaDetector driver John Hammonds
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Driver/Protocol for Lin Engineering Silverpak 23CE stepper motor Mark Rivers
Next: [EPICS] Support for Staged Installs ? Pavel Maslov
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
